Air only blow from defroster vent - JeepForum.com
post #1 of 8 Old 07-14-2017, 05:49 PM Thread Starter
GodlyBacon
Vacuum line help
I found a blue vacuum line that broke in half and can't find what it is for on my 89 xj
GodlyBacon is offline
post #2 of 8 Old 07-14-2017, 05:57 PM Thread Starter
GodlyBacon
I'm new to this jeep thing so, Air would only blow at defroster vent and not anywhere else on my 89 xj, any help or suggestion would be great
post #3 of 8 Old 07-14-2017, 05:59 PM Thread Starter
GodlyBacon
I'm new to the jeep repair thing.... the air would only blow from the defroster vent under the windshield and not anywhere else, help
post #4 of 8 Old 07-15-2017, 05:50 AM
bluejunior
bluejunior's Avatar
You'll want this: http://cruiser54.com
That said, defroster only is usually a vacuum leak or a problem with the actuator linkage under the dash.
Lifted, Locked, Stiffened
bluejunior is offline
post #5 of 8 Old 07-15-2017, 07:48 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Look here:
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #6 of 8 Old 07-15-2017, 08:16 AM
75SV1
On one of my '98s, it was the vacuum reservoir. It was missing. Kind of weird, it would work at certain times, then not.
75SV1 is offline
post #7 of 8 Old 07-15-2017, 10:58 AM
mschi772
1997 XJ Cherokee
Vacuum leak. Very common problem. Google.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #8 of 8 Old 07-16-2017, 07:14 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That could be one of two things.
but most likely because of the color, it's for the vacuum shifted front axle.
