Air on defrost - JeepForum.com
post #1 of 4 Old 03-19-2011, 06:00 PM Thread Starter
metalman1400
Air on defrost
i already checked the vacuum lines and found on broken that goes to the canister under left headlight. Still not working. Feel slight air coming from/near where the a/c lines go to the cabin. could a leak in those still cause this?
metalman1400 is offline
post #2 of 4 Old 03-19-2011, 08:14 PM
Paradise XJ
1988 MJ Comanche
You did not find all the vacuum leaks...keep looking.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #3 of 4 Old 03-19-2011, 10:47 PM Thread Starter
metalman1400
i checked them all...and all are plugged in and none are cracked anywhere. could it be the canister or evap
post #4 of 4 Old 03-20-2011, 10:10 PM Thread Starter
metalman1400
could the vacuum line be clogged?
a/c , defrost
A/C only comes out defrost maxacon3000 XJ Cherokee Technical Forum 7 09-15-2010 08:42 PM
no defrost McWood XJ Cherokee Technical Forum 5 01-02-2010 09:25 AM
defrost 99 xj kaxj XJ Cherokee Technical Forum 4 06-11-2008 09:57 AM
Defrost only WRFD17 XJ Cherokee Technical Forum 13 11-13-2004 10:37 PM
Defrost only,Help! Grant Wood XJ Cherokee Technical Forum 1 11-03-2004 11:09 AM
