air conditioning woes - JeepForum.com
post #1 of 7 Old 07-14-2012, 09:57 PM Thread Starter
bluejunior
bluejunior's Avatar
So I live in Texas, I love my AC, and until recently it has loved me.
The unit back in the dash that directs air to all the different vents is having issues, I can't use the recirc or hi and low air condition settings anymore, because it all just blows straight out of the windshield vent, which of course drags it through the sunlight and kills the cold factor quite a bit.
Point being, I need to replace that part of the ducting and I'm wondering if anyone has had to do this and how much of a pain I'm getting into. I'm a college student in an apartment so I can only really do projects that don't require a HUGE amount of time or more than general tools, so it's nice to know what to expect.
Also anyone had particular success/misery with specific brands of OEM replacements in the AC system?
Lifted, Locked, Stiffened
bluejunior is online now
post #2 of 7 Old 07-14-2012, 10:45 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Wondering why you need to replace any of the ducting ?
Originally Posted by bluejunior View Post
.....it all just blows straight out of the windshield
Start by making sure you have no vacuum leaks, the flapper valve that directs the air runs on engine vacuum. Inspect the vacuum ball behind the front bumper and all the hoses and rubber fittings.
CJ7-Tim is offline
post #3 of 7 Old 07-14-2012, 10:48 PM
Bbasso
Sounds like you have a vacuum leak...
listen for a hiss on the passenger side fender under the hood.
I tracked mine down to a leak that is behind the front bumper.
Bbasso is offline
post #4 of 7 Old 07-14-2012, 11:00 PM
ltrail
1984 XJ Cherokee
Sounds like they have you covered here. Try not to tear the whole thing apart to find a leak .
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #5 of 7 Old 07-15-2012, 09:17 AM
Saudade
1988 XJ Cherokee
Yep! You are welcome to point your favorite search engine at "Cherokee defrost only" and browse through the gazillion threads on this.
Saudade is offline
post #6 of 7 Old 07-15-2012, 01:28 PM Thread Starter
bluejunior
bluejunior's Avatar
Thanks everybody! I'll check for a leak. My last cherokee it really was the unit, so I just assumed it was that again.
post #7 of 7 Old 04-19-2013, 10:55 AM Thread Starter
bluejunior
bluejunior's Avatar
UPDATE: I forgot to ever come back and tell everyone the cause of the problem. It actually turned out to be a cracked plug for the Brake booster was the source of my leak. It's at the back driver's side of the engine bay, and apparently a common failure point. Anyone having a minor vacuum-leak related issue might want to check it. Replacing it also fixed a high-pitched whine that varied with engine speed that I had barely noticed until it was gone.
air conditioning supersal01 XJ Cherokee Technical Forum 2 06-09-2011 04:50 PM
air conditioning???? jwrangler91 XJ Cherokee Technical Forum 8 07-21-2010 10:40 AM
Air Conditioning tecumsa XJ Cherokee Technical Forum 10 07-05-2008 12:34 PM
More air conditioning help Beater XJ Cherokee Technical Forum 3 08-06-2007 10:37 AM
Air conditioning nujeepguy XJ Cherokee Technical Forum 5 06-21-2007 03:48 PM
