Air conditioning compressor/Fan died - JeepForum.com
post #1 of 7 Old 07-12-2010, 02:59 PM Thread Starter
PBriggs
1993 XJ Cherokee
My A/C fan and compressor stopped working suddenly the other day, just refused to turn on. A/C clutch does not engage, i have the fan hardwired to a switch in case i really need it so im guessing there is a sensor or fuse or relay blown somewhere, i have no idea where to start looking. I'm assuming the two are related, any ideas as to what could be the problem?
PBriggs is offline
post #2 of 7 Old 07-12-2010, 03:36 PM
cornbrizzle
1992 XJ Cherokee
your elect fan runs when your a/c compressor kicks on and when you get above 218*+/- . does it kick on from temp rise ? or have you jumped a wire to the fan to see if it still works ? Take it to an a/c shop and have them check your freon levels and pressures to see if your compressor is shot.
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #3 of 7 Old 07-12-2010, 03:51 PM
foggybottombob
There is a fuse and relay for both the A/C and the aux fan in the fuse box under your hood. Each item has its own relay and fuse. Those fuses are an easy thing to check. In my 91 XJ they are the two fuses and relays closest to the firewall.
foggybottombob is offline
post #4 of 7 Old 07-12-2010, 05:08 PM Thread Starter
PBriggs
1993 XJ Cherokee
Yes the electric fan works, i only see a relay for AC no fuse
PBriggs is offline
post #5 of 7 Old 07-12-2010, 05:18 PM
foggybottombob
I think you should see a relay and a small plastic fuse in front of the relay. The fuse is toward the passenger fender from the relay for each relay on my 91. I have not looked at a 93 to see what that fuse box looks like but I know a 97 is completely different in layout.
post #6 of 7 Old 07-13-2010, 09:17 AM Thread Starter
PBriggs
1993 XJ Cherokee
the fuses and relays are all intact, it does seem like a fuse blew or something though because they just stopped working suddenly, no weird symptoms or sounds/smells before
PBriggs is offline
post #7 of 7 Old 07-13-2010, 09:18 AM Thread Starter
PBriggs
1993 XJ Cherokee
Brizzle
if the compressor was shot i think the clutch would still engage correct? and would the compressor failure cause the fan to die also?
PBriggs is offline
a/c , air conditioning , electrical , fan , heat
how to convert a/c compressor to air compressor? walterm77 XJ Cherokee Technical Forum 3 07-07-2008 12:22 PM
bearing in air conditioning compressor Trev97 XJ Cherokee Technical Forum 1 09-24-2007 11:57 AM
air conditioning Grey4.0L XJ Cherokee Technical Forum 2 02-11-2007 08:33 AM
air conditioning compressor clutch causing squealing patchouli XJ Cherokee Technical Forum 3 11-14-2006 08:28 AM
2 questions- Spring compressor or not/Air compressor psi jaardesign XJ Cherokee Technical Forum 6 07-26-2004 07:10 AM
