Air conditioner stops cooling and then works again - JeepForum.com
post #1 of 8 Old 04-05-2007, 09:21 PM Thread Starter
QwkTrip
Warm weather is coming soon so I will have to deal with a problem that I have put off since last year. The air conditioner in my 2000 Cherokee works great for a while and then all of a sudden quits cooling. It blows humid outside air for about 5 minutes and then begins to cool again. Any ideas?
A friend suggested that there is a temperature switch that keeps the condensor from freezing. But I have no idea what to look for or if that is true.
Thanks for the help!
QwkTrip is offline
post #2 of 8 Old 04-05-2007, 11:36 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
First thing to check is the R134 level. See if it needs topped off or if there is a leak.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 8 Old 04-07-2007, 01:20 PM Thread Starter
QwkTrip
If the refrigerant was low then wouldn't it perform poorly consistently? This is an intermittent problem. The AC cools great when it's on. It just switches off completely from time to time.
QwkTrip is offline
post #4 of 8 Old 04-07-2007, 02:17 PM
wcbuyer
My '99 did this last year - it needed freon but still did it after it was added. It mainly does it in stop and go traffic and has done it this year also.
Charles
'99XJ
wcbuyer is offline
post #5 of 8 Old 04-07-2007, 06:28 PM Thread Starter
QwkTrip
Ya, it does occur more often driving at slow speeds which suggests it is related to temperature and/or pressure in the AC system. It really shouldn't be that hard to figure out for someone that is familiar with AC systems. I guess I'll need to start reading up and learn something new.
QwkTrip is offline
post #6 of 8 Old 04-07-2007, 08:26 PM
BrunoS
ok, if the r134a level is good, then next cause of this symptom is exapanison valve freezeup. happens when there is excess moisture in the refrigerant and it causes the water to freeze up where the liquid freon goes through a tiny orifice and expands to a gas in your evaporator (and gives frosty cool air)
you can't fix this yourself....here's why:
search for a coupon, then go to pep boys, goodyear, or whoever, and have them suck all the refrigerant out, change out the dessicant/dryer assembly, then recharge it with 134a and the right oil. that will fix your problem...but you have to get out all the moisture with a vaccum pump for quite some time.
for around $100, you should have working a/c again.
OR: go to pep boys, napa, kragen, look for the little a/c bottles that can fix these little problems...you need the can that will claim to get rid of excess moisture in the system. they sell them for around $10 and might be worth a try first. the stop leak has worked well for me.
let us know what you decide.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #7 of 8 Old 04-08-2007, 01:32 AM
madrabbitt
madrabbitt's Avatar
coolent level
poor connection on the compressor's power line.
those are your likely causes.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #8 of 8 Old 04-08-2007, 07:18 AM
MGrobe
Man In Black
MGrobe's Avatar
Mine was doing that 4 summers ago. It would work 20-30 minutes then I would have to shut it off for ten. Repeat.
My Jeep still had an extended warranty so my buddy at the dealer got to fix it for me. Something was freezing, whether it was what was mentioned above I couldn't say.
He did repair it and the problem hasn't existed since then. It sure was a PITA when driving from Chicago to Wash. DC.
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
Air Conditioner Relay? OtsiderCherokee XJ Cherokee Technical Forum 9 06-09-2008 12:40 AM
Air Conditioner Help Please! Stumedic XJ Cherokee Technical Forum 1 04-20-2008 03:33 PM
air conditioner red dye insurrection151 XJ Cherokee Technical Forum 9 06-09-2006 07:11 PM
Air Conditioner Fan cvining XJ Cherokee Technical Forum 7 07-26-2004 06:04 PM
Air Conditioner Screeching??? 1999JCS XJ Cherokee Technical Forum 5 08-14-2003 07:12 AM
