#1 | |
AHHHHHH! Gremilns!
okay so when i turn on my park lights/headlights, my passenger side park light on the front goes out. sometimes... only once in a while. sometimes it stays on but most of the time its off. if i take out the bulb while its running and clean the popsts/put it back in it works but then ten minutes later it doesnt, and i get the little arrow on my dash kind of half on half off sometimes all the way on sometimes all the way off
What the crap is going on? i cant find any wire problems nothings burned out not the fuse or the bulb and all the terminals for the light make good contact i have the right bulb and its driving me nuts i cant find the problem to save my life! HELP
lo tho i wheel through the valley of the shadow of death, i will fear no obsticle, for my jeep is with me. thy armour and tires, they comfort me. you lead me to lay down rubber on big rocks, and drive you through deep waters. you prepare a place for me at the end of tough trails, and you anoint my driveway with oil. surely your awesomeness and the smell of burning motor oil will follow me all of the days of my life, and i will dwell in the house of the jeep forever. amen. |
#2 |
OH i should also mention when the park light IS on it and the signal light are really really dim like barely on at times.
#3 |
German car snob
bad ground, probably. check all connections, and check to see if some wires are faulty. Also, you can take a multi meter to the parking light's wiring harness. I'd look in a FSM for the wiring schematic, and test the wires down the line. It is somewhere between the wiring harness for the light and the split from the main line going to the rest of the light.
- Brian Klein Concept and Design KCD Website Follow us on Facebook! XJ Writeups: | DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
