AH!!!! Jeep wont start!!!!!!!! - JeepForum.com
post #1 of 9 Old 01-07-2006, 10:27 PM Thread Starter
Jeepzter29
Soo..... try jumping my jeep... and it aint working..... I hit the the gas pedal a little bit and its turns on and i rev my engine once i let go of the gas its just dead!!!! What the heck is goin on!!!????
96 Cherokee Country
-6" Skyjacker
-Teraflex long arm kit
-35"x12.5" Good Year MTR's
Jeepzter29 is offline
post #2 of 9 Old 01-07-2006, 10:36 PM
CanadianJeep86
do you have to rev it high for it to run? IF so, MAP Sensor, lovely little thing bolted to the fire wall with a harness and a vacuum hose going to it
1984 Suzuki SJ410, 1.3L 5speed, soft top, spoa, shackles, bodylift, 6 offroad lights.
1988 Dakota, 318, 5 speed, 4.10's, rollbar, lowered 3".
1986 2dr XJ, 2.8, 5 speed, Bushbar,
1989 XJ, 4.0, AW4, NP231, D44, 3.73's, *Stolen*
1987 MJ Sportruck, 2.5, AX5, Rollbar, *Jeep Heaven*
1986 MJ, 2.5, T-5, bushbar, Longbox, *Jeep Heaven*
CanadianJeep86 is offline
post #3 of 9 Old 01-07-2006, 10:36 PM
XJ4oh
1997 XJ Cherokee
So you can get it to run as long as ya hit the gas? Thats what happened to me when my IAC sensor/motor went out.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #4 of 9 Old 01-07-2006, 10:37 PM
XJohnnyC
XJohnnyC's Avatar
Does the engine crank over slowly? Can you keep it running by revving it for a minute or two? Try that and see if it keeps running when you let off the gas.
Could be a bad battery. Someone told me that the computer can forget the idle and the engine will die if the battery is bad. Well, a new battery later, I haven't had the problem since.
XJohnnyC is offline
post #5 of 9 Old 01-08-2006, 04:10 AM
Koz83
I have the same issue. One day it starts like nothing's wrong, and the next I either a) don't get any response when I turn the key, nothing b) crank it and have to give it gas to keep it from dying or c) crank it, give it gas, then turn off the engine only to have it start normally the next time. I checked the battery and it seems fine (but I do know that sometimes the battery checks out but in reality needs to be replaced).
Problem is, I can't test this with another battery because this issue is so random. It can start without problems for a whole week and then gets *****y all of a sudden.
So which is it, the MAP sensor, the IAC sensor or the battery? Bah...
XJ - 1998 4.0 Sport 2-door - Gun-metal blue
- Current - Future -
Tranny: AW4 - Axles: Dana30; Chrysler 8.25 - T/case: NP231
Lift: 2" Daystar bb - 30x9.5 BFG AT KOs
Intake/Exhaust:2.25" Flowmaster 40 Deltaflow; Dynomax hi-flow cat
Koz83 is offline
post #6 of 9 Old 01-08-2006, 01:45 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Do you have a check engine light? Do you have sound fuel pressure? Do you have solid spark?
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #7 of 9 Old 01-09-2006, 01:49 AM
Koz83
Nope, no check engine light but I haven't checked the plugs for about a year. Seems like everything's good, no problems with fuel pressure or plugs.
Koz83 is offline
post #8 of 9 Old 01-09-2006, 08:17 AM
philipx
there is a ceramic resistor on the left inner fender in the engine compartment check that the spade connections are on it also check its not opene circuited I think that maybe your problem
Philipx
philipx is offline
post #9 of 9 Old 01-09-2006, 09:31 PM
XJohnnyC
XJohnnyC's Avatar
Philipx
Nope, that's the fuel pump ballast resistor. They didn't have them on a 96.
XJohnnyC is offline
jeep wont start right. girlinajeep XJ Cherokee Technical Forum 5 11-12-2009 07:36 PM
electric start prob. jeep wont start blackl4life XJ Cherokee Technical Forum 1 08-21-2009 09:56 AM
Angry Cherokee Wont Behave..start and die every 30 min! wont start then run 30 later! bcameron1974 XJ Cherokee Technical Forum 10 06-05-2009 02:22 PM
Please help, Jeep wont start!!! xstoyz XJ Cherokee Technical Forum 9 10-28-2004 03:11 PM
