Aftermarket Transmission - JeepForum.com
post #1 of 3 Old 03-14-2011, 10:43 AM Thread Starter
mjanulaitis
My wife as a 2001 XJ. The automatic transmission has a dual 1st/2nd position on the shifter. This format is unacceptable for crawling down or climbing up the steep snow packed roads which we live on. I'd like to replace the transmission or if possible modify it so the shifter has a position for 1st and 2nd which it will hold. Can anyone provide insight into a possible solution?
mjanulaitis is offline
post #2 of 3 Old 03-14-2011, 10:59 AM
chriskeenan
The transmissions shifting is electronically controlled by 2 solenoids.
S1 on, S2 off = 1st
S1 on, S2 on = 2nd
S1 off, S2 on = 3rd
S1 off, S2 off = 4th
S3 is the torque converter lock-up
Using a few simple electronic parts you can build a shift controller and hold the transmission in any gear.
Or you can buy and install one of these.
http://radesignsproducts.com/14Shiftcontrollers.aspx
Any of these solutions will trigger the check engine light, the code it throws is typically p07**.
chriskeenan is offline
post #3 of 3 Old 03-14-2011, 11:33 AM
blackgnx
1997 XJ Cherokee
You can modify the valve body and i bet Transgo has a kit. But that would require dropping the Vavle body... I like the wiring idea better...
blackgnx is offline
Aftermarket Transmission Cooler mx2times XJ Cherokee Technical Forum 3 11-13-2010 10:39 AM
is this an aftermarket cat kyleyz762 XJ Cherokee Technical Forum 6 07-25-2010 09:18 PM
Transmission whine on manual transmission 2nd gear Hubbazoot XJ Cherokee Technical Forum 2 11-23-2008 01:30 AM
where to get aftermarket TB wetazz XJ Cherokee Technical Forum 5 04-02-2007 07:51 AM
strange engine/transmission noise and oil leaking from transmission? weldmaster4000 XJ Cherokee Technical Forum 5 04-20-2006 01:06 PM
