Aftermarket Ignition System - JeepForum.com
post #1 of 2 Old 11-27-2011, 03:26 PM Thread Starter
GardenGnome5
Anyone ever install an aftermarket ignition system? An MSD ignition module and coil to be more specific.
Kind of curious where you mounted everything and I'm unsure of where to connect my 12V switch source.
If you have any experience with them post it up.
Thanks,
Gnome
96 Cherokee lifted, shoes, blah, blah, blah
89 YJ stock resto project
GardenGnome5 is offline
post #2 of 2 Old 11-27-2011, 04:16 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I have seen more flops with this than success stories. The reliability of the MSD electronics is surprisingly marginal. Early failure is not unusual.
My advice would be to stick with the stock system; it is all the ignition that the Jeep 4.0 engine needs.....
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
ignition , ignition module , performance
aftermarket Ignition system & idle problem ntneustadt XJ Cherokee Technical Forum 2 12-02-2010 07:04 PM
Does anyone run an MSD ignition system??? cher96 XJ Cherokee Technical Forum 18 02-23-2009 12:11 AM
Ignition system maintenance? 600dollarXJ XJ Cherokee Technical Forum 1 08-09-2006 07:03 AM
Ignition system discussion Jmila1901 XJ Cherokee Technical Forum 7 02-08-2006 02:00 PM
firepower ignition kit waste of money? whats best overall upgrade for ignition system woobles XJ Cherokee Technical Forum 0 07-28-2002 07:35 PM
