advice on family vehicle. So many problems since we brought home - JeepForum.com
post #1 of 7 Old 04-29-2012, 03:34 PM Thread Starter
maxamillion
1978 CJ7
me and my wife just recently bought a cherokee for the new to us family vehicle. Next thing we know misfire codes. I changed plugs, and got the cam sensor replaced. It was good again for two weeks then starts to over heat. We found out the Radiator was filled with gunk, so I bought a new radiator. it was good again then the misfire code pops on again Misfire in 1-3 Cylenders. then we find out the Radiator we bought started leaking in the driveway. So now it sits at Dodge i ordered the insulators for the injectors. My issue now is the Radiator i bought was from Autozone. the one they wanted me to buy was a four hundred dollar OEM one from o reilly. now that im in the same place i was im lost. has anyone else had any issues with using anything other than OEM. please guys help me out and those of you to say search yes ive been doing that. its getting aggrivating my wife is due any day now and im ready to sell this thing. it put my Jeep CJ rebuild to a Halt.
_______________________________________________
Never tell people how to do things.
Tell them what to do and they will surprise you with their ingenuity.
- General George Patton Jr
jeep cj part out
maxamillion is offline
post #2 of 7 Old 04-29-2012, 03:53 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The cooling system consists of more than just the radiator. You mentioned that the old radiator was full of gunk, so you need to 100% replace the cooling system components and chemically flush the block.
Cheap parts are cheap for a reason. If you plan on keeping any vehicle for an extended period of time, use the best quality parts you can afford. However, a decent Jeep radiator doesn't cost $400, more like $125-175.
CJ7-Tim is offline
post #3 of 7 Old 04-29-2012, 03:57 PM
the_weirdo
the_weirdo's Avatar
I hate radiators with plastic side tanks. Radiator Barn or DPG Offroad will have all-metal 3 core radiators for around $230 shipped. Or you can do a 2-core for a little under $200.
Sounds like you are doing the right thing on the injectors.
the_weirdo is offline
post #4 of 7 Old 04-29-2012, 04:03 PM Thread Starter
maxamillion
1978 CJ7
thats what i said i wasnt going to pay 400 for a radiator. everywhere in town was at 110 for radiators including oreillys where dodge was going to get it from. those were in the works i was pricing that stuff now as in water pump and heater core. but has anyone else had trouble with autozone radiators. that one had lifetime warranty so just get pulled out and take back.
jeep cj part out
post #5 of 7 Old 04-29-2012, 04:05 PM Thread Starter
maxamillion
1978 CJ7
thanks ill check that out. lesson learned about plastic sides.
jeep cj part out
post #6 of 7 Old 04-29-2012, 04:06 PM
jeepkid03
Winning
jeepkid03's Avatar
I second the advice for the DPG Offroad radiator. Best $230 I've spent on the jeep. On 100 degree days the temp never gets above 210*.
We need a bit more info on the jeep... Year? Engine? Trans?
Once these maintenance issues from the previous owner are sorted out, this Cherokee can be a very reliable rig.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #7 of 7 Old 04-29-2012, 04:12 PM
jeepkid03
Winning
jeepkid03's Avatar
I also recommend doing the Prestone flush kit. If your heater core isn't leaking, you can usually flush it out pretty good and be fine. They aren't much fun to replace. Autozone parts have been hit and miss for me. I try to avoid their parts on stuff that can leave me stranded. yeah, you get the lifetime warranty, but it doesn't help you much when you are stranded on the side of the road.
-Josh
Build Thread:
misfire , overheating , radiator , radiator clogged
Brought home a 99 XJ - finally back in to a Jeep! k6lor XJ/MJ Cherokee Non-Technical Forum 4 03-14-2011 05:43 AM
A/C problems, need advice jeeplasse XJ Cherokee Technical Forum 4 07-10-2010 05:23 AM
2 Problems any advice???? UTHornsFan XJ Cherokee Technical Forum 8 07-29-2006 09:59 PM
Towed the camper home, problems Thelt XJ Cherokee Technical Forum 12 01-22-2006 01:41 PM
Brought it home today! Need help..... hawkphan1 XJ Cherokee Technical Forum 7 08-14-2005 05:53 PM
