Adjustment - JeepForum.com
post #1 of 13 Old 08-29-2013, 01:25 PM Thread Starter
79chiefs
1988 XJ Cherokee
Adjustment
I have been trying to figure out my braking issues. I thought I have seen info on adjusting the pushrod for the MC. My braking system is all new. I have a little pedal travel before braking. I can panic stop and lock my brakes up, and they work well when the pedal is near the floor. I bought my booster and MC separately, is there a way to adjust the pushrod? I did a bit of googling but found conflicting answers.
88XJ
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #2 of 13 Old 08-30-2013, 04:51 AM Thread Starter
79chiefs
1988 XJ Cherokee
Bump-a-dump
95 E34 540i-DD
79chiefs is offline
post #3 of 13 Old 08-30-2013, 06:01 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
It's adjustable. Separate the MC and booster and carefully adjust, using some kind of measuring device.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 13 Old 08-30-2013, 08:12 AM
gs69350
Make sure the rear drums are properly adjusted first. The piston activates the rear brakes in the first part of travel, if the shoes aren't adjusted, they can make a soft pedal for the first part of pedal application.
1998 Jeep Grand Cherokee 5.9 Limited - Stone White - Stock for now.
<-- 5.9 Owner's group on FB.
gs69350 is offline
post #5 of 13 Old 08-30-2013, 01:12 PM Thread Starter
79chiefs
1988 XJ Cherokee
They are adjusted with new parts, i just got to thinking about my issue and thought about that rod, thanks guys. Is there any special tool or way to do it?
95 E34 540i-DD
79chiefs is offline
post #6 of 13 Old 08-30-2013, 03:19 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
When you take it apart, it will be so obvious what needs to be done.
post #7 of 13 Old 08-30-2013, 03:31 PM
jeepster383
I would think if you wernt having the problems b4 the brake job then it shouldn't be the push rod. Rather a bad part or something was done wrong.
jeepster383 is offline
post #8 of 13 Old 08-30-2013, 03:41 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
In his first post:
post #9 of 13 Old 08-31-2013, 01:32 AM
jeepster383
Originally Posted by cruiser54
In his first post:
Disregard
post #10 of 13 Old 09-02-2013, 12:45 PM Thread Starter
79chiefs
1988 XJ Cherokee
Did the adjustment, and bled again, now i have great brakes, thanks guys!!!!!!!!!
95 E34 540i-DD
79chiefs is offline
post #11 of 13 Old 09-02-2013, 01:43 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
And you were so worried about it!!
Actually, I stumbled upon that years ago and have found many times the booster rod to master cylinder clearance is off.
post #12 of 13 Old 09-02-2013, 02:34 PM Thread Starter
79chiefs
1988 XJ Cherokee
I guess that may have been the issue with all the travel in the original MC it had some wear and could have worked its way to being loose, i saw no leaks when messing with it off the jeep and it worked well just messing with it. But I have peace of mind knowing i have a new one.
95 E34 540i-DD
79chiefs is offline
post #13 of 13 Old 09-02-2013, 03:26 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You're good to go.
