-   -   Adjustment (http://www.jeepforum.com/forum/f11/adjustment-1568768/)
79chiefs 08-29-2013 01:25 PM
Adjustment
I have been trying to figure out my braking issues. I thought I have seen info on adjusting the pushrod for the MC. My braking system is all new. I have a little pedal travel before braking. I can panic stop and lock my brakes up, and they work well when the pedal is near the floor. I bought my booster and MC separately, is there a way to adjust the pushrod? I did a bit of googling but found conflicting answers.
88XJ
79chiefs 08-30-2013 04:51 AM
Bump-a-dump
cruiser54 08-30-2013 06:01 AM
It's adjustable. Separate the MC and booster and carefully adjust, using some kind of measuring device.
gs69350 08-30-2013 08:12 AM
Make sure the rear drums are properly adjusted first. The piston activates the rear brakes in the first part of travel, if the shoes aren't adjusted, they can make a soft pedal for the first part of pedal application.
79chiefs 08-30-2013 01:12 PM
They are adjusted with new parts, i just got to thinking about my issue and thought about that rod, thanks guys. Is there any special tool or way to do it?
cruiser54 08-30-2013 03:19 PM
When you take it apart, it will be so obvious what needs to be done.
jeepster383 08-30-2013 03:31 PM
I would think if you wernt having the problems b4 the brake job then it shouldn't be the push rod. Rather a bad part or something was done wrong.
cruiser54 08-30-2013 03:41 PM
In his first post:
jeepster383 08-31-2013 01:32 AM
Originally Posted by cruiser54
In his first post:
Disregard
79chiefs 09-02-2013 12:45 PM
Did the adjustment, and bled again, now i have great brakes, thanks guys!!!!!!!!!
cruiser54 09-02-2013 01:43 PM
And you were so worried about it!!
Actually, I stumbled upon that years ago and have found many times the booster rod to master cylinder clearance is off.
79chiefs 09-02-2013 02:34 PM
I guess that may have been the issue with all the travel in the original MC it had some wear and could have worked its way to being loose, i saw no leaks when messing with it off the jeep and it worked well just messing with it. But I have peace of mind knowing i have a new one.
cruiser54 09-02-2013 03:26 PM
You're good to go.
The time now is 05:05 AM.
