Adjust the sway bar? - JeepForum.com
post #1 of 9 Old 06-12-2008, 07:09 PM Thread Starter
bigalpha
1995 XJ Cherokee
My front end clunks when I am backing out with the wheel turned. I can see where the sway bar mounting point on the passenger side has rubbed on the spring and chipped away the protective coating.
At the time, it was obvious that the swaybar was loose, so I tightened it up (hand tight). Now there's even more clunking noises coming from both sides.
How do you properly tighten a swaybar? Is it supposed to be kind of loose or tightened all the way down?
On the other hand, what's the proper adjustment for the front swaybar? Is it possible to rotate it towards the grill some to make sure it doesn't hit the springs?
I'm trying to get some pictures, but it's like a zillion degrees outsides so my camera lens is still foggy. grrr.
The susp. pics are here: Susp. pics
bigalpha is offline
post #2 of 9 Old 06-12-2008, 08:21 PM
cc cherokee
cc cherokee's Avatar
Looks like you have stock sway bar links. You need to buy longer ones or some adjustable quick disconnects to rotate the bar up and avoid contact with the coil. Tighten the upper and lower link bolts nice and snug. You should inspect the sway bar bushings too while you're at it. Good luck. HTH
cc cherokee is offline
post #3 of 9 Old 06-13-2008, 11:04 AM Thread Starter
bigalpha
1995 XJ Cherokee
yeah, the bushings looked pretty bushed (har har). Do you think that's what could be causing the pop/clunking sounds? It happens the most when I'm turning and backing up.
bigalpha is offline
post #4 of 9 Old 06-13-2008, 11:06 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
This Is Why You Need Longer Swaybar Endlinks When You Install A Lift Kit.
Those drop brackets aren't long enough. Also, notice how the studs on the top of your endlinks are now bent?
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #5 of 9 Old 06-13-2008, 11:26 AM
Magus2727
1995 XJ Cherokee
after what size of lift should you get new / longer links?
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline
post #6 of 9 Old 06-13-2008, 11:40 AM
Vendor
1995 XJ Cherokee
Anything taller than a budget boost.
Jason West -
post #7 of 9 Old 06-13-2008, 03:14 PM Thread Starter
bigalpha
1995 XJ Cherokee
Whoo, easy. I didn't get the Jeep lifted, it was already lifted when I got it. That's why I'm here looking for advice. This is my first vehicle that is lifted and a Jeep.
I'm learning as I go.
bigalpha is offline
post #8 of 9 Old 06-13-2008, 03:31 PM
Vendor
1995 XJ Cherokee
Just get some longer endlinks. If you plan on wheeling the Jeep much, invest in some quick disconnects from JKS or Rubicon Express. If you're the DIY type and are willing to trade some ease of use for cost, you can convert your stock endlinks into disconnects and lengthen then at the same time -- http://jeepin.com/features/discons
Jason West -
post #9 of 9 Old 06-13-2008, 03:33 PM Thread Starter
bigalpha
1995 XJ Cherokee
Thanks for the link. I'll look into that. Looks much cheaper than buying commercially.
bigalpha is offline
How do i adjust.. badlands1 XJ Cherokee Technical Forum 4 02-20-2009 08:56 PM
Can you adjust your IAC ? wildgarden XJ Cherokee Technical Forum 8 01-08-2007 09:33 PM
How to adjust TPS? mideerhunter XJ Cherokee Technical Forum 3 10-11-2006 02:28 PM
Tps Adjust nemethjames XJ Cherokee Technical Forum 2 10-08-2006 11:40 PM
Do I need to adjust the TPS? CheechTheJeep XJ Cherokee Technical Forum 6 05-22-2006 07:44 PM
