Adding leafs to 4.5" lift spring pack? - JeepForum.com
post #1 of 7 Old 08-20-2009, 10:19 AM Thread Starter
Admiral_Doom
Hey guys, got a weird question. I recently put on a 6" lift kit I got secondhand. Problem is, the PO used 2" blocks with 4.5" spring packs, and the passenger side is sagging almost an inch due to axle wrap. I got 2" lift shackles to replace the blocks. My question is...can I use a leaf or 2 from an S10 pack to compensate? I know about bastard packs but I want to know if S10 leaves have the correct arch to correct my saggy spring. If it is possible, should I use the full length leaf or one of the smaller ones? Thanks in advance!
Admiral_Doom is offline
post #2 of 7 Old 08-20-2009, 11:15 AM
99Greenmachine
Probably the main spring would add an inch...
you'd have to play around with it and see. Which aftermarket leaf springs are they?
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #3 of 7 Old 08-20-2009, 11:20 AM Thread Starter
Admiral_Doom
The PO said they were RE but can't be sure
post #4 of 7 Old 08-20-2009, 11:23 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would try adding in the main leaf cut to fit, or the second leaf where it would fit in the pack and see what happens.
xjfever is offline
post #5 of 7 Old 08-20-2009, 11:30 AM
justanotherjpr
It will be a bit of a mix and match trial and error to get it where you want, but it should work.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #6 of 7 Old 08-20-2009, 11:34 AM Thread Starter
Admiral_Doom
Cool! Thanks guys! Ill report on how it goes, probably gonna try next weekend
post #7 of 7 Old 08-20-2009, 12:25 PM
Luke94XJ
1994 XJ Cherokee
I'm with justanotherjpr on this one. I added the lower 3 from a 6" to another 6" in place of its bottum 2 I gained 1.5 inches
Luke94XJ is offline
2" lift. Full spring pack Scottmc01 XJ Cherokee Technical Forum 5 07-02-2007 10:19 PM
rustys 3" spring pack lift boredcherokee4l XJ Cherokee Technical Forum 9 01-14-2007 09:32 AM
Question about Rusty's 3" XJ Spring Pack lift drew and not u XJ Cherokee Technical Forum 11 07-17-2006 04:10 AM
adding leafs to RE pack silverxj2001 XJ Cherokee Technical Forum 0 06-12-2005 10:36 PM
rear spring pack vs. add a leafs CLB XJ Cherokee Technical Forum 10 03-16-2003 09:10 PM
