Adding freon - low pressure line? - JeepForum.com
post #1 of 2 Old 09-06-2002, 12:28 PM Thread Starter
28_SM
I need to charge the system in my 91 Cherokee...Was wondering if anyone could tell me which of the two lines is the low pressure line (to add freon). Thanks,
28_SM is offline
post #2 of 2 Old 09-06-2002, 01:20 PM
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
All of the low pressure lines are the larger diameter lines. The pressure valve to add freon is close to the accumalator/ drier, which wiil be on a large line. The hose that hooks to the valve will only seat down on the correct line. It is set up to be almost fool proof!!! Of course, there are exceptions!!
1997 Black XJ Sport 4x4, 1" Shackle/coil spacer lift, Ram Brush guard w/ 6in spot lights, Smittybilt Nerf bars, Class III Hidden Hitch, Elliptical Driving Lamps, Prime Wheels#234 15x8.5, 30x9.50r15, BFG AT's, JVC CD player, Alpine V12 Amp, 1-12in RockfordFosgate Subs, 5-1/4 Rockford Fosgate component speakers in doors & sound bar, Euro-spoiler, Pacesetter Cat-Back, Optima Red Top battery, HID Headlamp Conversion, Gabriel Hijacker Air Shocks on rear axle
Gacherokee is offline
Line pressure solenoid 05 Cherokee 4.7 Nfrederick XJ Cherokee Technical Forum 2 01-27-2010 09:31 AM
Power Steering Pressure Line str8_6_Jeep XJ Cherokee Technical Forum 8 04-12-2009 08:34 PM
99 Trans Pressure line is leaking jeepnatv4life XJ Cherokee Technical Forum 3 11-03-2008 09:08 PM
Pressure Gauge on Transmission cooler line akxj01 XJ Cherokee Technical Forum 1 09-23-2008 05:41 PM
Adding Freon 28_SM XJ Cherokee Technical Forum 3 09-13-2002 09:52 AM
