Add-A-leaf help - JeepForum.com
post #1 of 8 Old 05-22-2013, 03:55 PM Thread Starter
Dcoy
Add-A-leaf help
Hello again after a few short jeepless months, I now am a proud owner of a mint one owner ( old lady ) 99 cherokee and plan on installing a 2" lift. I plan on an aal in the rear but my stock springs are alittle saggy and wanted to know if I should get a 3" lift aal to compensate for the old springs or would a 2" lift spring be fine? Thanks
P.S. I want to get a long leaf not a short one.
Dcoy is offline
post #2 of 8 Old 05-22-2013, 04:12 PM Thread Starter
Dcoy
I was looking at rustys offroads add-a-leaf
Dcoy is offline
post #3 of 8 Old 05-22-2013, 07:53 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
AAL is probably not a great fix for saggy leaves.
***Chris***
chris87xj is offline
post #4 of 8 Old 05-22-2013, 08:51 PM
paparker21
1991 XJ Cherokee
What is your desired ride height? What is your current ride height? Desired - Current = X where X is the lift you need. Chris is right though - if your springs are truly saggy (like, they sit flat with your vehicle not loaded to the brim with gear) then an AAL will only provide you a temporary solution. A whole new leaf pack isn't terribly expensive and will provide 1) A longer lasting result 2) A more predictably flexy spring 3) A overall better feel for many many more miles.
paparker21 is offline
post #5 of 8 Old 05-23-2013, 05:51 AM
tyvanwie
Aals won't fix sag. You're better off just getting new ones. It'll save you money in the long run.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #6 of 8 Old 06-26-2013, 06:32 PM Thread Starter
Dcoy
Just to update, I got a good deal on stock spring packs so I just put my aal lift on them then installed it on the jeep. Rode pretty high in the rear for a few weeks but settled down to a good height. Happy with the results, thanks, now only if I can fix the 50mph shaking......
Dcoy is offline
post #7 of 8 Old 06-26-2013, 06:48 PM
dave564
Take a look at the tires, see if one has a bunch of weights on it. That rim probably bent. Good chance, you know how little old ladies drive....
dave564 is offline
post #8 of 8 Old 06-26-2013, 06:52 PM Thread Starter
Dcoy
Thanks man but the old lady rims are long gone, have new black steelies on it, had them balanced them twice to.
Dcoy is offline
