Add a leaf - JeepForum.com
post #1 of 5 Old 03-12-2011, 07:41 PM Thread Starter
no5son1962
Add a leaf
My son has a 99 XJ and the rear springs are sagging significantly. He does not have alot money so I was wondering if I could use an old spring that I have cut the ends off of it and install it in the leaf pack like a Add-A-Leaf. The springs that I have are significantly thicker than the stock leaves. If you think it will work where in the pack should it be installed.
Thanks
no5son1962 is offline
post #2 of 5 Old 03-12-2011, 07:46 PM
TrailRider94
yes you can do that, whats the leaf out? do you know?
TrailRider94 is offline
post #3 of 5 Old 03-12-2011, 07:54 PM Thread Starter
no5son1962
I have no clue what the leaf is out of. It was here when I moved into my house. Upon closer inspection it is a single leaf that has broken in half. The whole leaf, both parts together, is about 50 inches long.
post #4 of 5 Old 03-12-2011, 08:07 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can buy a set of S-10 leafs from the junkyard and build a set of bastard packs for around 50.00, that would be the best option in your situation. An AAL or a set of shackles won't help much with already sagging leafs.
xjfever is offline
post #5 of 5 Old 03-12-2011, 08:08 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
There is a great deal of info here -> http://www.jeepforum.com/forum/f11/t...ks-tsbs-89273/
S-10 leaf springs are very inexpensive, easy to find at the junkyard or on CraigsList, and can boost saggy leaf packs. The local U-Pull-R-Parts sells leaf springs for $11 each.
CJ7-Tim is offline
Procomp Leaf Spring Packs (remove overload leaf for 2")? grizbait XJ Cherokee Technical Forum 6 11-29-2010 12:11 PM
Removing a leaf from a leaf pack Muddeprived XJ Cherokee Technical Forum 5 08-17-2010 03:19 PM
Add-a-leaf vs. Full leaf packs... throttlejunkie1 XJ/MJ Cherokee Non-Technical Forum 11 06-20-2009 11:45 AM
adding a leaf to a RE4.5" leaf pack EricsXJ XJ Cherokee Technical Forum 6 10-29-2004 09:40 PM
