ac/heater problem - JeepForum.com
post #1 of 5 Old 11-10-2007, 02:24 AM Thread Starter
joe86
ac/heater problem
my ac/heater is acting weird and i cant find the problem. heater and ac works but it just stays on the window defrost setting. when i move the lever (to heat,vent, bi-lev, etc.) it just stays on defrost. i pulled the control panel out and took everythin apart thinkin it was a bad electrical connection or sumthin but everythin looked good. could my puddle jumpin last weekend caused this even tho this problem started about 2 days ago?
joe86 is offline
post #2 of 5 Old 11-10-2007, 03:21 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Check the vacuum bulb behind the bumper. Make sure the lines are tight on it. Trace the lines up and feel for damage to them.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 5 Old 11-10-2007, 08:24 AM
rstarch345
If you don't find any problems with the vacuum lines, check the operation of the blend door under the dash. It uses a vacuum actuator and they can go bad.
2K XJ - 6" lift w/ 34s
'98 XJ Laredo - Stock (and staying that way)
'71 M151
I'm a proud member of
rstarch345 is offline
post #4 of 5 Old 11-10-2007, 08:27 PM Thread Starter
joe86
thanks guys. ill check those right now
joe86 is offline
post #5 of 5 Old 11-10-2007, 11:44 PM
jersey_jim
jersey_jim's Avatar
1994 XJ Cherokee
i had the same problem, on the vac line that goes into the firewall... on that T connector, the line that came off the bottem and went into the firwall, if it was pushed onto the T connector too much it woldnt work, if i pulled it down a bit, the heater/ A/C worked fine on all the settings.
94 xj - 5.5" rubucon express long arm, 4.56's, shafted & Detroit locked on 35's
jersey_jim is offline
Heater Problem jeepnick XJ Cherokee Technical Forum 1 10-30-2009 01:25 AM
heater problem 99XJRider XJ Cherokee Technical Forum 1 12-12-2007 10:16 PM
heater fan problem skunkmere XJ Cherokee Technical Forum 4 10-20-2006 07:32 AM
heater problem cherokeejoe XJ Cherokee Technical Forum 2 12-16-2005 05:29 PM
Need Help with Heater Problem projectX XJ Cherokee Technical Forum 1 01-25-2004 08:11 PM
