AC Fixes? - JeepForum.com
post #1 of 3 Old 08-12-2014, 06:53 AM Thread Starter
Caseycoo07
AC Fixes?
Hey everyone. Seems like this may be a no brainer to most but I'm new to the jeep repair thing. Usually I take it to the shop. So here's my problem, the vents in the car aren't blowing any air. At least not through the front. I get all the air, regardless of what the setting is, through the vents on the top of the dash blowing on the windshield. Any ideas on what it could be? I checked behind the glove box but nothing looked out of place or loose. Any help would be appreciated. Thanks.
Caseycoo07 is offline
post #2 of 3 Old 08-12-2014, 07:43 AM
Amesbear
It's because of a bad vacuum line. If you have cruise control, that probably doesn't work either. The lines run along the passenger side of the engine bay. Replacement vacuum sets run about $15 at a Jeep dealership.
My XJ thread: http://www.jeepforum.com/forum/f177/im-back-xj-2628914
Amesbear is offline
post #3 of 3 Old 08-14-2014, 09:06 AM
bluejunior
bluejunior's Avatar
x2 on the vacuum lines. Look for a cracked line, check the little black plastic vacuum reservoir on the passenger side of the bumper (looks like a black softball with lines coming out of it) and while you're at it double check the vacuum line plug on the Brake Booster. I had a slight leak there too.
Lifted, Locked, Stiffened
bluejunior is offline
air conditioner , fix , not working
