AC fan blows fuse. - JeepForum.com
post #1 of 4 Old 06-15-2012, 07:52 AM Thread Starter
Xanatos
1991 XJ Cherokee
AC fan blows fuse.
I few weeks ago my blower fan blew the fuse. I changed out the fuse a few times, but it never worked. It always blew as soon as I tried to turn the fan on. I still believe the AC and heat work, I can put my hand right next the the vent and barely feel the cold/hot air. Does anyone know what might be a problem with this? Maybe a bad fan motor? or something else?
Live free. Stay wild.
Xanatos is offline
post #2 of 4 Old 06-15-2012, 01:13 PM
Reptile
1991 XJ Cherokee
It will keep blowing til you find the short. Most likely you have an exposed wire that's causing a short to ground. The fan could be the cause but you can easily test it with the ohmmeter mode of a volt meter. Resistance leaning to zero indicates a bad motor.
Reptile is offline
post #3 of 4 Old 06-16-2012, 07:39 AM Thread Starter
Xanatos
1991 XJ Cherokee
Alright, thanks! I'll try to look for any exposed wires. I'm still new to the Jeep world and still learning how to repair things. I might stop by an auto parts store to see if they can test my fan.
Xanatos is offline
post #4 of 4 Old 06-16-2012, 07:47 AM
Ron_K
I had the same issue and looked for a short, hopefully you find your issue quickly, mine raN HOT without the fan and Not using the ac.
Mine wound up being the fan motor itself, hit up Napa and done
Good Luck
"You're only Limited by Your Own mind."
91 YJ, rear body armor with rock rails and TJ filler conversion. LED Tail lights. 33 x 15.50 x 15 SS TSL SX's on black steelies. Home made Bumpers and swing out tire carrier. MileMarker H9000 Winch, H/T & Bikini Top, full doors & half doors. ~RIP~ C.D.K. 11-11-08 (miss you baby)
NTM 1989 XJ 2 Door Cherokee Sport, I6/auto/Swingout carrier, Custom Stereo system that makes my heart skip a beat.. IT'S My New DD and da^% happy to say I finally own one ;)
Ron_K is offline
96 XJ blows 20A fuse when using turning signals Svenlylethor XJ Cherokee Technical Forum 14 09-27-2011 02:19 PM
xj blows fuse need help ausburn15 XJ Cherokee Technical Forum 1 01-08-2009 08:19 PM
xj Engine control fuse blows on start up ecm? noel86 XJ Cherokee Technical Forum 1 12-17-2008 12:33 PM
high RPM blows eng ctrl fuse xjhabitat XJ Cherokee Technical Forum 0 10-07-2007 07:55 PM
fuse 11 blows when shifting to reverse Vegard XJ Cherokee Technical Forum 5 08-20-2006 10:50 AM
