AC compressor removal/idler replacement - Page 2 - JeepForum.com
post #16 of 24 Old 06-29-2017, 11:34 PM Thread Starter
al_xv
1989 XJ Cherokee
I made some progress on my radiator project today. With the radiator and condenser out, I had the absolute best access to this bracket. I pulled the old one off and did a test fit to make sure everything looked good. The idler pulley lines up with the bracket so itís going on. I may run it with two bolts for now so I can get my other projects moving along also.
Itís an easy swap if you can find the bracket from a 92-95 XJ at a good price. Just 4 bolts, 3 into the block/head and one through the timing case cover. The bolt through the cover is hidden by the pulley so it is helpful to remove the fan and pulley. I'll swap over my idler as that bering feels a little better.
As you can see in the photo, the snapped bolt is the front most, closest to the head.
The snapped bolt is still holding tight. I havenít tried heat yet but that might be in order. One thing to note on that bolt; I was able to get a good 4 or 5 revolutions after I cracked it loose initially and then as I was unscrewing it, it began to seize up and that is when it snapped, where the most rust was. So it wasnít totally seized with rust when I broke it loose. I suspect it should be easier to get out once I can get a solid grip.
Lots of cleaning to do still before I finalize this install.
1989 stock 2 door LTD XJ w/ 4.0L + AW4
and 4 Volvo 240s
al_xv is offline
post #17 of 24 Old 07-02-2017, 02:52 AM
Charley3
Originally Posted by Charley3 View Post
I have an idler pulley bracket and pulley I bought from O'Reilly. It's a Dorman brand. It works good and eliminates the compressor.
This is been a great mod for me. I never once missed my AC. Though I do live in a Northern climate where AC isn't really needed.
Summer this year is hotter than hell in my local area. That's unusual for this area. It doesn't usually get that hot here. I'm missing the Jeep AC this year. My solution is to drive my Buick on hot days because its AC works.
Even so, I'm glad I removed it from the Jeep because it wasn't working anyway. So at least I got to save some weight and not have it kicking on the AC compressor and electric engine fan in the Winter when I run the defoggger/defroster. It defrosts/defogs plenty fast, partly because I have a 205F thermostat which makes the heat nice and warm.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #18 of 24 Old 07-03-2017, 06:58 AM
spistols
Dumb question, but seems like the answers/members on this forum may know the info- I have to remove my AC Compressor in my 1993 XJ for the mere fact of getting to a snapped Oil Pressure sensor switch. I do not need to disconnect, just move out of the way until I make the sensor repair-AC blows nice and cold now. Easy/Hard? Any known problems of any more bolts snapping- Lord knows I do not need anything more to snap, as this is what started this in the first place.
Thanks for any info.
spistols is offline
post #19 of 24 Old 07-03-2017, 09:39 AM Thread Starter
al_xv
1989 XJ Cherokee
If you just need to move the compressor out of the way, you should be able to do that with the compressor still hooked up. Once you start disconnecting the high or low side A/C lines you'll have to get the system re-charged. Is the switch you need to fix on the receiver/dryer? If it is mounted in the same location as in my 89 XJ (under the compressor, next to battery), there is a single stud/nut holding it to the body. You can remove that nut and move the dryer around to get better access. It's down at the bottom, pointing straight up. If you decide to pull the compressor off I'd recommend soaking the bolts down and taking your time removing them. If you can, loosen them a couple of turns and then spray the penetrating oil into the holes below the bolt heads. I was in a bit of a hurry at the JY getting my bracket, so my problem may have been preventable.
and 4 Volvo 240s
al_xv is offline
post #20 of 24 Old 07-05-2017, 07:18 AM
spistols
Compressor
Al_XV
Thanks for the response. Basically, I only need to move the compressor out of the way, to gain access to the oil pressure sensor I stupidly broke trying to remove.
A local shop wanted to charge in excess of $750 just because of how labor intensive this job is, as I understand it is labor intensive, but not that much $ worth, for me.
spistols is offline
post #21 of 24 Old 07-05-2017, 04:10 PM
Charley3
Al_XV
It's not that labor intensive, unless they don't know what the're doing or are ripping you off. My cousin removed my compressor in 15 or 20 minutes with hand tools. If he had air tools it would have been faster. If he had been moving it over temporarily, and then back again, then maybe an hour if he doddled and ate at sandwich while working.
My cousin isn't even a pro. Well, not exactly. He's a backyard mechanic who works on a lot of family and friends cars. Maybe he's a semi-pro at most.
I would avoid the shop that said $750 because IMO they're incompetent and/or dishonest.
Charley3 is offline
post #22 of 24 Old 07-05-2017, 04:14 PM
Charley3
I'm not a mechanic, but it's so simple I'd have done it myself, if I wasn't badly handicapped from a car wreck.
Charley3 is offline
post #23 of 24 Old 07-17-2017, 06:39 AM
spistols
Fixed the complete problem, for @ $50, and in @ 4.5 hours. Not bad for saving $700 on a Saturday afternoon!
spistols is offline
post #24 of 24 Old 09-11-2017, 08:19 PM Thread Starter
al_xv
1989 XJ Cherokee
...well, back to the original thread, a follow up on this idler replacement.
Out of the box, the A/C bypass pulley felt solid. After bolting it to the AC bracket, I found it was offset from the belt path. There was a spacer provided in the box and I installed it between the pulley bearing and the bracket. I tightened up the bolt that hols it to the bracket and it seemed fine until I got the belt on and tight, and started it up. Somewhere there is a slight amount of play and it kind of rattles when the engine is running. It's more noticeable when you increase the RPMs. The bearing seems to be fine but something about the pulley itself is allowing for some play. The bolt holding all that together is also solid. Since the plastic pulley seems really cheap, has anyone replaced it with a metal one? Whats the best way to go about finding a replacement pulley that would work with one of these pulley brackets since it doesn't have to actually transfer the rotational force to another part?
My concern is it's going to fail from this extra vibration, so I'm want to prevent that if possible.
and 4 Volvo 240s
al_xv is offline
a/c , compressor , delete , idler pulley , removal
