ABS stopped working - JeepForum.com
post #1 of 7 Old 12-14-2005, 06:03 PM Thread Starter
jaardesign
jaardesign's Avatar
ABS stopped working
Hi guys, thanks for taking the time to help me out. All of a sudden my ABS isnt working any more. The ABS dash light isnt on so I dont know whats going on, all I know is that if I even feather my breaks on ice the wheels completely lock up and theres none of the ABS studder. Please Help. What could be wrong? Any easy fixes I could try?
Thanks Alot!!
'92 4x4 4door Cherokee Limited with 100k
RE 4.5" lift with full leaf packs, adjustable LCAs (with SkidRow skidplates)and UCAs, adjustable track bar, JKS discos, front and rear steel breaded brake lines, DPG bump plates, front+rear hitch, and 31" bfg ATs
Colorado rocks!
jaardesign is offline
post #2 of 7 Old 12-15-2005, 11:15 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Have you checked the ABS fuse?
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 7 Old 12-15-2005, 11:20 AM
BryanFoster
When you turn on you're XJ does the ABS check light come on?
I had the same problem, and all it was, was the fuses for the ABS had come loose, so I pulled them out cleaned them off and put some Di-Electric grease in there and problem solved. Give that a go.
1992 Jeep Cherokee Laredo
4.0L HO, 4WD, Maroon, Stocker!
BryanFoster is offline
post #4 of 7 Old 12-15-2005, 11:35 AM
Matt Gertsch
www.lp.org
post #5 of 7 Old 12-15-2005, 12:56 PM
BryanFoster
No, I mean the check light. Not the ABS trouble light. I mean when u turn ur jeep on, the ABS light is suppost to come on for a few seconds.
post #6 of 7 Old 12-15-2005, 01:43 PM Thread Starter
jaardesign
jaardesign's Avatar
Hi, I checked the ABS fuse on the fuse box and the fuse is okay, but i found two slots labeled ABS and one doesnt have a fuse at all. I guess it never had a fuse in the first place.
When I first turn my key to ON, the Check Engine, Maintinance required, and the Check ABS lights in the dash come on for about 3 seconds and then go off.
Colorado rocks!
post #7 of 7 Old 12-15-2005, 03:35 PM
mikeypmcg
mikeypmcg's Avatar
abs sucks
From what I understand the computer is set up to control the abs based on your wheel size since you have changed the wheel size the computer isnt sending the correct information to your wheels. Every person I have known to change their tire size has ended up screwing up their ABS this includes cars and trucks. find a way to get rid of it, and drive it the way people have for 50 years b4 there was abs. PUMP THE BRAKES!!! I believe there have been some posts about removing the ABS. GOOD LUCK
1998 Jeep Cherokee Sport6.5" Rough Country Lift (yes I like it)33x12.50x15 BFG KM2 Mud Terrains,Woods rear D.S.
Advanced Adapters SYE D30 front Chr. 8.25 rear AX15 Man Trans NP231, C-Rok steering reinforcement
check it out at:
mikeypmcg is offline
Speedometer stopped working Khary23 XJ Cherokee Technical Forum 10 12-16-2008 06:54 PM
A/C Stopped Working Dannyboy18 XJ Cherokee Technical Forum 4 05-29-2008 09:28 PM
speedo stopped working AlexsXJ XJ Cherokee Technical Forum 3 01-12-2008 02:07 PM
Found out why my aux fan stopped working CraigAllen XJ Cherokee Technical Forum 3 06-09-2007 12:56 PM
speedometer stopped working?! cucr3 XJ Cherokee Technical Forum 7 03-20-2006 03:28 PM
