About to Install a 3.5" Lift; Question about Shackle Impact - JeepForum.com
post #1 of 16 Old 10-24-2013, 12:22 PM Thread Starter
lokithecoyote
So, I'm about to install a Rubicon Express 3.5" Superflex Kit (both upper and lower front control arms) and 3" front and rear shocks, and I am going to be replacing my rear leaf shackles as well. Now, the RE leaf springs say they will add 3.5" to lift, and most shackles on the market also mention adding at least 1" to a lift as well. If I replace my rear shackles, even at 1" lift, will my rear end be higher than my front end? Will I be able to compensate my front end using spacers even if I have the short control arms? Should I just go ahead and get long or adjustable control arms? Also, will my shocks end up being too short for the end actual lift height?
I was also thinking about getting the RE boomerang shackles for the rear, which are only supposed to give an additional 1" lift. Thoughts?
Thanks for the input.
The time you enjoy wasting is not wasted time.
lokithecoyote is offline
post #2 of 16 Old 10-24-2013, 12:46 PM
lazyxj
A shackle adds half of its height to the lift, a 2" shackle will add 1" of lift because it is lifting only on end of the leaf spring.
With many lift shackles, it is necessary to trim a bumper mounting bracket bolt that the shackles run into, under full compression.
A lift shackle will also change the axle to drive shaft orientation and may need to have angled axle shims installed or changed to eliminate drive shaft vibrations.
2001 Sport, 4" lift, 33 X 10.50 KOs, R.E. DB, R.E.-UCA, JKS-LCA, ACOS, 8.25-4.56-TruTrac, SYE, D-30 E-locker w/alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Lots of armor, Towing baseplate.
lazyxj is offline
post #3 of 16 Old 10-24-2013, 01:42 PM Thread Starter
lokithecoyote
So, I should just go with stock replacement shackles, then? These won't have those problems?
post #4 of 16 Old 10-24-2013, 02:19 PM
habbyguy
Or you could do what I did, and install the lift kit and see where you actually end up, and then "fine tune" the stance by choosing exactly the right shackles. In my case, I ended up 1/2" or so low on the back, so made it up with slightly longer shackles.
habbyguy is offline
post #5 of 16 Old 10-24-2013, 04:48 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I am running 3.5" RE springs when adjustable upper and lower teraflex arms they work great. I still have a stock shackle. I will say I netted 4.5" in the front and 5.5" in the rear when I installed the lift. Now the jee lists at 4" and 4.25" over stock. I also have a decent bit of armor on my Xj also
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 16 Old 10-24-2013, 04:55 PM
maimedsk8er
After 3" lift you can compensate for CA length by shimming them forward at the LCA's body mount. This is only effective up to 4.5" as after that you'll want to use CA drop brackets to keep downward travel. Or switch to long arms. Nothing wrong with spacers to even out your ride or axle angle after a lift shackle set is installed. Boomerangs aren't necessary and more flexible side to side than a straight shackle
Every man deserves a 'Hummer' once in a while.
But no man should go without a great 'Jeeping' at least three times a week!
maimedsk8er is offline
post #7 of 16 Old 10-24-2013, 08:05 PM Thread Starter
lokithecoyote
Hah, I think I understood...MOST of that. What does CA mean, again?
post #8 of 16 Old 10-24-2013, 08:26 PM
Tom95YJ
Tom95YJ's Avatar
CA = control arm and shimming the factory arms is just dumb it's a stupid idea, Boomerang shackles do not flex more side to side. I really want to start smacking people on here who give horrible advise
Sent from AutoGuide.com App
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #9 of 16 Old 10-24-2013, 09:55 PM Thread Starter
lokithecoyote
Oh my God, of course it means control arm. I understand I will probably be upgrading to long-arms in the future, but I don't want to get new tires (the 30s I have on were brand new when I bought it, and anything over 3" would probably look silly with smaller tires) and I'm happy with it being a road warrior for a little while. Not mention gearing and everything...but yeah, I'm probably not going to be going with shim or blocks in my setup, and it looks like stock shackles will be the deal for now.
Thanks for the input!
post #10 of 16 Old 10-25-2013, 04:22 PM
PhotoJared
Thats about where I sit with my RE 3.5" kit. Honestly the rear doesnt flex a whole lot with the RE leafs and stock shackle. If you want to keep the 3.5" and not add lift, look into leaf sliders for the XJ.
example of horrible flex (the front is not disconnected):
'99 XJ Sport
It has a lift
It has 31's
It also other stuff
PhotoJared is offline
post #11 of 16 Old 10-25-2013, 07:26 PM
maimedsk8er
Here we go. Another person hating on somebody's advice. Welcome to Jeepforum everybody, where if it isn't your idea it's just "dumb" or "stupid." I ran 3/8 E- shaped shims in my LCA body mounts for over a year with no issue. Only changed it due to drop brackets. Now are those stupid too? Tell the site sponsors that.
As for the boomerang thing, better go take a few courses in physics my friend.
Cheers.
post #12 of 16 Old 10-25-2013, 07:44 PM
Motorcharge
Cheers.
Different opinions aren't stupid or dumb, but bad advice, like this post, are. What do site sponsors have to do with anything?
OP why do you NEED to change the stock shackles?
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #13 of 16 Old 10-25-2013, 09:29 PM
Tom95YJ
Tom95YJ's Avatar
Here we go. Another person hating on somebody's advice. Welcome to Jeepforum everybody, where if it isn't your idea it's just "dumb" or "stupid." I ran 3/8 E- shaped shims in my LCA body mounts for over a year with no issue. Only changed it due to drop brackets. Now are those stupid too? Tell the site sponsors that. As for the boomerang thing, better go take a few courses in physics my friend. Cheers.
Well since you are a physics major please post pictures and videos of boomerang shackles twisting. I bet stock style shackles react the same way. I have run boomerang shackles on Several Jeeps and they never twisted or bent. If they were not safe why would every lift company offer them and recommend them over regular shackles. Oh that's right cause they work better.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #14 of 16 Old 10-25-2013, 09:31 PM
Tom95YJ
Tom95YJ's Avatar
Originally Posted by PhotoJared
Thats about where I sit with my RE 3.5" kit. Honestly the rear doesnt flex a whole lot with the RE leafs and stock shackle. If you want to keep the 3.5" and not add lift, look into leaf sliders for the XJ. example of horrible flex (the front is not disconnected):
Mine flexes fine with stock rear shackles
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 16 Old 10-25-2013, 09:35 PM Thread Starter
lokithecoyote
The bushings are shot on them. I was going to just replace the bushings, but since new shackles are only 15 bucks or so (and these ones have some wear), I figured I'd go ahead and have them replaced. Guy at the dealership recommended just switching them out, so that's how I went.
Thats about where I sit with my RE 3.5" kit. Honestly the rear doesn't flex a whole lot with the RE leafs and stock shackle. If you want to keep the 3.5" and not add lift, look into leaf sliders for the XJ.
Are leaf sliders a replacement for shackles? How do they add more flex? I kind of like the idea of adding a shackle with lift later on when I add a bumper, roof rack, or something with weight to the rear. Could please explain a bit more - and thank you for the responses!
lift , lift advice , shackles
