99XJ died while driving no start HELP! - JeepForum.com
post #1 of 13 Old 10-05-2013, 10:49 AM Thread Starter
Why J?
Why J?'s Avatar
The 99 XJ 4.0l, auto 144.000 miles. Just bought it 4 days ago. Wife was driving and it died in the neighborhood. She had trouble getting it started but was able to and got it home. Then no start.
Fuel pump primes and I have pressure at the rail. I tested the CPS and it appears to be good.
Switched relays around no change Tested all fuses. None blown.
It appears to have no spark.
I am thinking CPS is bad even thought it tested good or possibly the coil.
Help me please.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #2 of 13 Old 10-05-2013, 11:03 AM
offroadfreak69
Check your power to the CPS
offroadfreak69 is offline
post #3 of 13 Old 10-05-2013, 11:11 AM Thread Starter
Why J?
Why J?'s Avatar
What would cause that to not be good?
Why J? is offline
post #4 of 13 Old 10-05-2013, 11:12 AM Thread Starter
Why J?
Why J?'s Avatar
And how?
Why J? is offline
post #5 of 13 Old 10-05-2013, 06:02 PM Thread Starter
Why J?
Why J?'s Avatar
No one has any other ideas here? Advice?
I'm struggling here.
Why J? is offline
post #6 of 13 Old 10-05-2013, 06:21 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Crank sensor and ignition coil are primary suspects. In that order.
Testing of the crank sensor CAN be inconclusive. If you buy a new crank sensor, buy a Mopar unit directly from Jeep for the best reliability. Aftermarket units are very "hit and miss" with a lot of miss!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #7 of 13 Old 10-05-2013, 06:40 PM Thread Starter
Why J?
Why J?'s Avatar
Originally Posted by tjwalker
Crank sensor and ignition coil are primary suspects. In that order. Testing of the crank sensor CAN be inconclusive. If you buy a new crank sensor, buy a Mopar unit directly from Jeep for the best reliability. Aftermarket units are very "hit and miss" with a lot of miss!
I picked up both the CPS and coil from my local dealer this afternoon. Just left the UT - Georgia game and plan to put the CPS in and then the Coil. If that doesn't work. I don't have a game plan past that.
Why J? is offline
post #8 of 13 Old 10-05-2013, 07:03 PM Thread Starter
Why J?
Why J?'s Avatar
So I get home and just for fun I crank it. No start. Then I try to cycle the key 3 times to see if maybe I can pull a code. Nope. Then I crank it. It starts runs for 30 seconds perfectly then shuts down. Back to no start.
Why J? is offline
post #9 of 13 Old 10-05-2013, 08:41 PM Thread Starter
Why J?
Why J?'s Avatar
Replaced CPS and she is a running! Better than ever as a matter of fact. Going out for a test drive should be good to go.
Why J? is offline
post #10 of 13 Old 10-06-2013, 06:42 AM Thread Starter
Why J?
Why J?'s Avatar
I wanted to add that my bad CPS tested good for others that experience this problem
Why J? is offline
post #11 of 13 Old 10-06-2013, 08:10 AM
bucklee00
1981 CJ5
So the CPs fixed it? Our Cherokee is doing the same thing!
bucklee00 is offline
post #12 of 13 Old 10-06-2013, 08:28 AM Thread Starter
Why J?
Why J?'s Avatar
It sure did. I was doubtful it would because mine tested good.
Got the Mopar CPS for $75 from the local dealer.
Why J? is offline
post #13 of 13 Old 10-06-2013, 09:32 AM
bill7987
2008 KK Liberty
Check ur coil mine did this when I first got mine and I just popped the plugs off and cleaned the corroded connections and she fired right up.
bill7987 is offline
