99 XJ Sometimes won't start - Page 2 - JeepForum.com
post #16 of 21 Old 05-15-2011, 02:11 PM Thread Starter
Lukey
Grrrr! Put the starter back in and it started right up. This is getting aggravating!!!
Lukey is offline
post #17 of 21 Old 05-15-2011, 11:28 PM
mspies1
Check the voltage between the battery and the fuse box ( the lead that goes to the front of the box under the little cover). Touch the negative side of the battery and the fuse box lead. The voltage should be the same over that as well as the battery. If its anything less you need a new cable. Do the same for the starter
I know a lot of ppl that have had the cable die. Make sure that all of the connections are clean using electric cleaner.
I know you have probably already have done this, but try and wiggle the wires around this time because it can have a short in the line and not know.
Hope this helps
RE 3.5 SF w/ adj arms, S-10 4" leafs, Front hitch, rear DIY bumper, 31" BFG ATs, D-Window w/ 4.5 BS
mspies1 is offline
post #18 of 21 Old 05-20-2011, 05:44 PM Thread Starter
Lukey
Thanks everybody...
I just want to close the loop on this. We replaced the starter (it had a loose solenoid lead) and the ignition switch and it has taken care of this issue. I think the ignition switch was the culprit because the problem got worse after we put the new ignition lock cylinder in. So it makes sense that the switch it activates was also worn and was probably the reason it sometimes wouldn't fire up.
Lukey is offline
post #19 of 21 Old 05-20-2011, 07:12 PM
hxcjohnny
edit. sorry, didnt read the entire post.
02 WJ Overland
hxcjohnny is offline
post #20 of 21 Old 08-11-2013, 11:39 AM
timnelly
I cannot get my xj to crank using the key, it cranks if i use power wire to starter but still wont start. Ground problem? Ignition problem?
timnelly is offline
post #21 of 21 Old 08-11-2013, 06:39 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
You're "hijacking" this thread. Start a new one.
It will give you more accurate replies and keep this thread on track. It gets confusing when more than one problem is being replied to.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
1998 XJ Won't start on 1st try, fires right up on 2nd attempt / slow start spenceuiuc XJ Cherokee Technical Forum 18 08-06-2012 06:26 AM
No start......Replaced the Crank Sensor and still no start, Whats UP? batilzown XJ Cherokee Technical Forum 3 02-17-2010 12:50 PM
electric start prob. jeep wont start blackl4life XJ Cherokee Technical Forum 1 08-21-2009 08:56 AM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 08:18 PM
Eh.. start? no start? roll the dice? jiggle the cable? UnderDog! XJ Cherokee Technical Forum 6 05-25-2006 09:14 AM
