99 xj seems like stuck right front locked - JeepForum.com
post #1 of 3 Old 07-18-2010, 03:24 PM Thread Starter
link4889
hey guys. ok i have a 99 xj sport. and just recently after hitting a deep pothole it feels as if the right front is locked when i turn. When going straight down the road its fine. but when i make turns its feels like as it locks and releases. it rocks the steering wheel in turns. i just did wheel bearing hubs to it and it had new u joints installed over a year ago. i had it in the air at work and was spinning the right front and it locks up when the wheels turn the left front spins freely. i cant figuer out if its locked in for wheel drive id preferably not open the diff im thinking the u joint possibly went bad again? any help will greatly be appreciated. thanks
link4889 is offline
post #2 of 3 Old 07-18-2010, 04:22 PM
tjjeepwrench978
1997 XJ Cherokee
check your caliper bolts, u joints gears
tjjeepwrench978 is offline
post #3 of 3 Old 07-18-2010, 04:23 PM
supertaco
brakes are jammed somehow im guessin
supertaco is offline
fron differential , front axle problem , u joint
'89 Cherokee Rear hatch/Liftgate is stuck and/or locked... lc317nv XJ Cherokee Technical Forum 1 12-27-2009 03:11 PM
URGENT! 4 Wheel Drive Locked/Stuck-Undriveable! Jeeps4u XJ Cherokee Technical Forum 11 12-09-2009 09:32 PM
96 XJ - Passengers Door Stuck Locked (partially open) gregmondro XJ Cherokee Technical Forum 0 08-12-2009 10:54 AM
front wheels locked HELP!!! nickXJcherokee XJ Cherokee Technical Forum 5 07-14-2009 01:12 PM
Front/rear locked and DD xj BMX xj XJ Cherokee Technical Forum 10 10-03-2007 02:50 PM
