'99 XJ idle - JeepForum.com
post #1 of 6 Old 01-27-2011, 05:10 PM Thread Starter
Jackpine
'99 XJ idle
Here's what I have.
Starts fine. Runs fine. If I stop somewhere and turn it off for maybe five minutes then start it again and start down the road, it bogs down bad unless I pump the gas and then it catches up. It doesn't do this when I initially start it.
This morning I started it to warm it up before work. When i was inside, I heard it surging at idle. When I got out there, I gave the accelerator a pump and it settled into a straight idle. First time for that.
Any ideas? Thanks.
Jackpine is offline
post #2 of 6 Old 01-27-2011, 05:18 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Any check engine light ever seen? If so, you must pull stored codes for clues.
In the absence of codes, I'd start with cleaning throttle body and idle air control. Just good maintenance regardless. And if that doesn't resolve it, test your THROTTLE POSITION SENSOR.
The Idle Air Control (IAC) is mounted on the back of the throttle body. The valve controls the idle speed of the engine by controlling the amount of air flowing through the air control passage. It consists of a stepper motor that moves a pintle shaped plunger in and out of the air control passage. When the valve plunger is moved in, the air control passage flows more air which raises the idle speed. When the valve plunger is moved out, the air control passage flows less air which lowers the idle speed. Over time and miles, the IAC can get carboned up which can have an adverse affect on idle quality. Cleaning the IAC may restore proper function and is an easy procedure to perform and good preventive maintenance so it is never a bad idea.
CLEANING THE JEEP 4.0 IDLE AIR CONTROL
Remove the air filter cover, associated hoses and the rubber boot that goes from the air filter cover to the throttle body. Remove the IAC with a torx driver (2 bolts; one can be kind of hard to get to)
“Gently” wiggle out the IAC from the throttle body. Gasket on the IAC can be re-used if it is not damaged
Clean the IAC with a spray can of throttle body cleaner; inexpensive and available at any place that sells auto parts. Throttle body cleaner is recommended rather than carburetor cleaner as it is less harsh, safe for throttle body coatings and is best for this task. Use cleaner, a rag and a toothbrush and or Q-Tips. Be gentle; don’t twist or pull on the pintle that protrudes from the IAC as it is fragile and you could damage it.
Thoroughly spray clean and flush where the IAC seats in the throttle body with the same spray cleaner
It is also a good idea to clean the entire throttle body itself, the butterfly valve inside of the throttle body and all associated linkage as long as you have things disassembled
Reinstall IAC and check idle quality
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 6 Old 01-28-2011, 12:27 PM Thread Starter
Jackpine
Thanks tjwalker. I'll give it a try tonight. No codes came up.
Jackpine is offline
post #4 of 6 Old 02-05-2011, 04:35 PM Thread Starter
Jackpine
Pulled and cleaned IAC. Idles nice now but it still did the stall thing today. After I have to give it the gas, it does it's bog down thing, catches up and then it's ok throughout the drive.
How do I test the throttle position sensor?
Jackpine is offline
post #5 of 6 Old 02-05-2011, 04:37 PM
tjwalker
tjwalker's Avatar
The throttle position sensor is connected to the throttle shaft on the throttle body. It sends throttle valve angle information to the PCM. The PCM uses this information to determine how much fuel the engine needs. The TPS is really just a simple potentiometer with one end connected to 5 volts from the PCM and the other to ground. A third wire is connected to the PCM. As you move the accelerator pedal with your foot, the output of the TPS changes. At a closed throttle position, the output of the TPS is low, about a half a volt. As the throttle valve opens, the output increases so that, at wide open throttle, the output voltage should be above 3.9 volts. Testing can be performed with an electrical meter. Analog meter is best. You are looking for a smooth sweep of voltage throughout the entire throttle band. While slowly opening and closing the throttle, take note to the movement of the voltmeter needle. There should be a direct relationship between the needle motion to the motion of the throttle. If at anytime the needle moves abruptly or inconsistently with the movement of the throttle, the TPS is bad
You should have 5 volts going into the TPS. At idle, TPS output voltage must be greater than 200 millivolts. At wide open throttle (WOT), TPS output voltage must be less than 4.8 volts.. The best is to use an analog meter (not digital) to see if the transition from idle to WOT is smooth with no dead spots. With your meter set for volts, put the black probe on a good ground like your negative battery terminal. With the key on, engine not running, test with the red probe of your meter (install a paper clip into the back of the plug of the TPS) to see which wire has the 5 volts. One of the other wires should show .26V (or so). The other wire will be the ground and should show no voltage. Move the throttle and look for smooth meter response up to the 4.49 at WOT.
Perform the test procedure again and wiggle and/or tap on the TPS while you watch the meter. If you notice any flat spots or abrupt changes in the meter readings, replace the TPS.
The TPS is sensitive to heat, moisture and vibration leading to the failure of some units. The sensor is a sealed unit and cannot be repaired only replaced. A TPS may fail gradually leading to a number of symptoms which can include one or more of the following: -
NOTE: The throttle position sensor is also DIRECTLY involved with transmission shifting characteristics! It should be verified early in the troubleshooting process, when a transmission issue is suspected!
 Poor idle control: The TPS is used by the ECU to determine if the throttle is closed and the car should be using the Idle Air Control Valve exclusively for idle control. A fault TPS sensor can confuse the ECU causing the idle to be erratic or "hunting".
 High Idle Speed: The TPS may report faulty values causing the engine idle speed to be increased above normal. This is normally found in conjunction with a slow engine return to idle speed symptom.
 Slow engine return to idle: A failing TPS can report the minimum throttle position values incorrectly which can stop the engine entering idle mode when the throttle is closed. Normally when the throttle is closed the engine fuel injectors will be deactivated until a defined engine RPM speed is reached and the engine brought smoothly to idle speed. When failing a TPS will not report the throttle closed and fueling will continue causing the engine to return to idle very slowly.
 Engine Hesitation on Throttle Application: The TPS is also used by the ECU to determine if the driver has applied the throttle quicker than the Manifold Air Pressure sensor can read. The fueling is adjusted acordingly to cope with the sudden increase in air volume, however a faulty sensor can cause the ECU to ignore this data and the engine will "hesitate" when applying the throttle. In extreme cases with the engine at idle, a sudden application of full throttle can stall the engine.
 Engine Misfire: A fault TPS can report values outside the deined acceptable range causing the ECU to incorrectly fuel the engine. This is noticable as a slight misfire and can trigger the misfire detection software and/or Malfunction Indicator Lamp (MIL) light on the dashboard. Extreme cases can cause excessing misfires resulting in one or more cylinders being shut down to prevent engine and catalytic converter damage.
tjwalker is offline
post #6 of 6 Old 02-05-2011, 05:11 PM Thread Starter
Jackpine
Thanks tj. Do you think that would cause the hesitation after start? I guess the check would rule it out. Again, the problem is only after a second start after the Jeep has been sitting. If I jump in right away after first start, I don't get the hesitation.
Jackpine is offline
turn wheel at idle = idle drops to ~400 RPM Willy36 XJ Cherokee Technical Forum 1 04-11-2010 07:02 PM
Rough idle, stumble at idle. 98xjnick XJ Cherokee Technical Forum 2 03-23-2010 03:18 PM
no vac leaks - backfire, rough idle, fast idle, slow response alhefner XJ Cherokee Technical Forum 7 09-16-2009 12:58 AM
will the air idle control make a moter idle too fast? mhall101 XJ Cherokee Technical Forum 19 06-10-2009 09:10 AM
Light knocking noise at idle (and slightly slow idle) Calpolyclimber XJ Cherokee Technical Forum 14 04-28-2004 04:37 PM
