99 turn signals not working - JeepForum.com
post #1 of 5 Old 01-09-2005, 01:22 PM Thread Starter
46CJ2A
Just purchased a 99 cherokee, and the turn signals are not working. The fuse is good, and i checked, and have 12 volts coming into the fuse block, at the fuse. The flashers will not work either, and the signal blinker lights do not light up on the dash , nor due i hear the clicking noise. where should i look? I though it may be the blinker thing by the fuse panel, but am not sure, because there still arent any lights onthe dash?
46CJ2A is offline
post #2 of 5 Old 01-09-2005, 01:25 PM
anony91xj
Probably the flasher. Newer Chrysler vehicles use what's called a "combination flasher", one flasher for all the blinkers and the hazards. That's probably the culprit.
1998 VW GTI 2.0
anony91xj is offline
post #3 of 5 Old 01-10-2005, 10:18 AM Thread Starter
46CJ2A
Where is this flasher module thing located at. Is it by the fuse block?
46CJ2A is offline
post #4 of 5 Old 01-10-2005, 11:43 AM
Osteonis
Osteonis's Avatar
2008 KK Liberty
Have you checked all the bulbs?
99 XJ Sport
Stock
I6
5spd
Class III Hidden Hitch
235/75/15
Bumper Mounted Fogs
Osteonis is offline
post #5 of 5 Old 01-10-2005, 03:36 PM
puckjer
the combo flasher relay is located behind the panel under the steering wheel. just undo the 3 screws and pull the panel off and you will see it
2007 JK 2dr sahara, dual tops, 2 in Rubicon Express lift, 32" BFG M/Ts
puckjer is offline
front turn signals not working in 87 xj the87XJkid XJ Cherokee Technical Forum 1 08-16-2009 05:55 PM
Turn signals not working............ g26 XJ Cherokee Technical Forum 1 05-26-2009 10:37 PM
turn signals not working cardana24 XJ Cherokee Technical Forum 4 10-09-2006 11:56 AM
Turn signals stopped working Jenniegirl XJ Cherokee Technical Forum 3 03-02-2006 08:00 PM
turn signals and hazards not working. puckjer XJ Cherokee Technical Forum 2 11-15-2004 05:22 PM
