'99 starting issue - JeepForum.com
post #1 of 3 Old 04-01-2011, 08:59 AM Thread Starter
topcat1
'99 starting issue
My '99 has a problem starting every now and then. Turn the key and it sounds and feels like it wants to start, but it won't turn over. Turn the key again, hold it and it will fire up after about 5-10 seconds. ignition switch?
Sucks having 2 xj's with problems at the same time....
topcat1 is offline
post #2 of 3 Old 04-01-2011, 09:25 AM
XJH-007
XJH-007's Avatar
#1- Check and clean your battery terminals. Bad battery connection can cause your symptoms and much more strange issues.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #3 of 3 Old 04-01-2011, 09:27 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Agreed that connections and grounds need to be verified before looking elsewhere. Simple stuff first.
Remove battery cables, clean them and the battery posts until SHINY, and reattach.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
Starting issue? Or not? Crunch XJ Cherokee Technical Forum 4 03-29-2010 02:13 PM
98 XJ 4.0 Starting Issue... rustedxj XJ Cherokee Technical Forum 3 09-21-2009 06:55 PM
89 2.5L starting issue whitebull72 MJ Comanche Technical Forum 1 08-19-2009 02:33 PM
Starting Issue Dannyboy18 XJ Cherokee Technical Forum 3 12-12-2008 07:14 AM
starting issue 89SAFARIXJ XJ Cherokee Technical Forum 9 09-15-2008 10:14 PM
