99 jeep cherokee o2 sensor - JeepForum.com
post #1 of 6 Old 04-10-2012, 03:10 PM Thread Starter
me77
My check engine light came on the other day and when we checked it, we got the p0141 code - oxygen sensor heater circuit bank 1 sensor 2. Does this mean my sensor is bad or the circuit involving the sensor has a problem. Also where exactly is the sensor located? I have a regular 99 jeep Cherokee with a 4.0L engine.
me77 is offline
post #2 of 6 Old 04-10-2012, 03:18 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Possible causes
- Rear Heated Oxygen Sensor wire harness is short circuit or open circuit
- Rear Heated Oxygen Sensor wire connector poor electrical connection
- Faulty Rear Heated Oxygen Sensor
- Inappropriate fuel pressure
- Faulty fuel injectors
- Exhaust Manifold leaks
CJ7-Tim is offline
post #3 of 6 Old 04-11-2012, 10:24 PM
Gutz88
1997 XJ Cherokee
Yea check the wires.. I replaced mine to later find out this was the problem[/IMG]
Gutz88 is offline
post #4 of 6 Old 04-11-2012, 10:25 PM
Gutz88
1997 XJ Cherokee
Uploaded with ImageShack.us
Gutz88 is offline
post #5 of 6 Old 04-14-2012, 02:11 PM
Dbiked
Where were those chafed at? Because I've got both O2 sensor circuits setting off my cel
Utah jeep crew member #32
Dbiked is offline
post #6 of 6 Old 04-14-2012, 09:48 PM
Gutz88
1997 XJ Cherokee
Thats the front one. I followed it to the top off engine. Thats right before it goes into the (main?) wire harness,,,
Also found that same thing on the wires coming from my MAP sensor..
Gutz88 is offline
oxygen sensor , P0141
98 jeep cherokee sport rear o2 sensor? fozzies jeep XJ Cherokee Technical Forum 1 06-05-2011 07:32 PM
How do you get at a 4.7L 99 Jeep Grand Cherokee Limited 4 crankshaft position sensor SierraNev XJ Cherokee Technical Forum 2 12-22-2010 02:33 PM
97 Jeep Grand Cherokee CMP Sensor Location jeeperxj97 XJ Cherokee Technical Forum 1 10-02-2010 03:31 PM
How do change a cam sensor on 1999 jeep grand cherokee lowside XJ Cherokee Technical Forum 1 05-08-2010 01:04 PM
1999 Jeep Cherokee Battery Temperture Sensor ridebmxfbm XJ Cherokee Technical Forum 5 03-28-2010 09:17 PM
