99 Jeep Cherokee ignition switch locked up! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 99 Jeep Cherokee ignition switch locked up!
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 11-22-2012, 05:38 AM   #1
LWechterPA
I have a 1999 Jeep Cherokee Sport 4.0 and have been having problems with the ignition key switch locking up. Key goes in but will not always turn. Is there a link to removing the ignition switch and replacing it? Thank you in advance. You guys have saved me lots of money with your advice.
LWechterPA is offline   Reply With Quote
Unread 11-22-2012, 07:10 AM   #2
kenC
sometimes when mine acts up i jiggle the shifter then it works,usually when i am shutting it off
kenC is offline   Reply With Quote
Unread 11-22-2012, 08:03 AM   #3
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
The ignition switch is probably fine, and the key cylinder is the problem.
Remove the ignition cylinder and clean it with some throttle body cleaner. Use a light gun oil to lubricate it. While you have it out, check the silver ignition switch pin for breakage.
Watch the Video, Cherokee are similar -
According to the National Shooting Sports Foundation, AR-15 sporting rifles account for nearly 20% of all U.S. firearms sales.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
