99 Jeep Cherokee 4.0 Banging when in drive. - JeepForum.com
post #1 of 4 Old 07-28-2012, 05:17 PM Thread Starter
wjl6944
1999 FSJ Cherokee
Let me start with this. I am NO mechanic by any means. My problem is I have a 1999 Jeep Cherokee 4WD with the 4.0 liter engine that has been banging when in drive and going down the road. It happens on hills and on the flat and it does not seem to matter at what speed it is going. The banging is almost like an older model vehicle when you would put it in reverse and would make that bang from the tranny except this happens when it is in drive and and it is moving. The problem is intermittent and does not happen all the time. I have been checking the fluids every day and the motor runs great aside from a very slight lifter tap. I just had the transmission serviced, but this did not fix the problem, and the mechanic which I trust says the tranny is working great. I recently noticed that the exhaust is getting loud from the area near the catalytic converter. Could the banging be a exhaust problem? If not any ideas?
Any help will be greatly appreciated.
wjl6944 is offline
post #2 of 4 Old 07-30-2012, 07:21 PM
Rtbeebe
1997 XJ Cherokee
Does the noise sound like it is right under your feet? Do you feel a thud in the floor? It may be that your transmission mount on the crossmember is loose.
97 Cherokee sport 4WD w/ 4.0
Rtbeebe is offline
post #3 of 4 Old 07-30-2012, 08:12 PM
Callelle
1997 XJ Cherokee
Sounds like the exhaust is making contact with the cross member.
Callelle is offline
post #4 of 4 Old 08-01-2012, 09:03 AM Thread Starter
wjl6944
1999 FSJ Cherokee
thud on floor.
Rtbeebe thank you and yes to both I will look in to the Rtbeebe
wjl6944 is offline
catalytic converter , cherokee , exhaust , knocking , transmission
Jeep Cherokee 4 wheel drive Glavus XJ/MJ Cherokee Non-Technical Forum 11 06-18-2012 11:39 AM
Help hard time starting 89 Jeep Cherokee after drive Tintman XJ Cherokee Technical Forum 6 10-24-2010 10:05 PM
when i put my 1995 jeep cherokee sport in drive it clunks lionsdetroit XJ Cherokee Technical Forum 10 06-16-2010 08:54 PM
I have a problem with the 4 wheel drive in my 2000 jeep cherokee missy9039 XJ Cherokee Technical Forum 8 12-30-2009 09:28 PM
4 wheel drive banging 1988XJ XJ Cherokee Technical Forum 1 02-15-2009 06:52 PM
