99 Classic XJ 4X4 Sway Bar Diameter - JeepForum.com
post #1 of 6 Old 01-31-2012, 06:02 PM Thread Starter
critmuncy99
Needing to buy new sway bar bushings for a stock 99 XJ Classic, Needing to know the size. There R sizes from 25mm to 28mm. Any help lol. Thanks ahead of time.
(J-E-E-P) Chew Them Up And Spit Them Out The Other End (J-E-E-P)
critmuncy99 is offline
post #2 of 6 Old 01-31-2012, 06:37 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You have to measure yours. Different option packages used different sizes. Use a caliper or micrometer. Or, you can try to gauge it by putting a 22-28mm metric open end wrench on it.
CJ7-Tim is offline
post #3 of 6 Old 06-15-2013, 04:31 AM
Chessa99XJ
I was gonna ask the same thing
Thanks for askin first!
Chessa99XJ is offline
post #4 of 6 Old 06-17-2013, 11:38 PM
Charley3
Holy **** Batman!
The OP is asking the exact same question I asked a couple months ago in another thread and then I got flamed by several people for asking such a stupid question. Several people told me (very rudely) that all XJs came with same sway bar and the package didn't matter.
I thought I'd read years ago that the package matters and determines the sway bar size. I was right.
Well good for Tim for answering this. Thanks. Much appreciated!
Do you think tow package XJs have thicker swaybars? In any case, I can just measure, now that I know there is a reason to.
Thanks again Tim.
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #5 of 6 Old 06-18-2013, 03:06 AM
Timo_90xj
Timo_90xj's Avatar
IIRC rear sway bars are the same an all XJs (if it was equipped with one from the factory), but there are a couple different diameters for the front sway bar.
I've had the thickest one an all of my XJs, and seems to me all the XJs sold here in Finland have had the 28mm version. I've seen a couple import models that came with the thinner ones.
***Under construction***
Timo_90xj is offline
post #6 of 6 Old 06-18-2013, 12:58 PM
Charley3
My stock rear sway bar was removed. The best mod I've ever done. Much softer on road ride (when a bump hits only on side of XJ), much better articulation off road, and it corners almost as well as.
My stock front sway bar is to stiff. I'm going to replace it with a Currie Anti-Rock adjustable front sway bar. It has 5 adjustments for different levels of stiffness from firm to soft, and 3 medium settings to choose from.
I had a Currie AR on an LJ in the past. Really nice. I ran it on softest setting on and off road and it was great.
Charley3 is offline
front sway bar diameter Scott00TJ XJ Cherokee Technical Forum 3 12-26-2010 01:06 PM
Sway Bar Diameter by Year? crcashman XJ Cherokee Technical Forum 8 11-04-2008 06:56 PM
Sway Bar diameter?? XJRookie XJ Cherokee Technical Forum 15 06-05-2008 09:46 PM
sway bar diameter Derka XJ Cherokee Technical Forum 4 03-03-2008 06:08 PM
sway bar diameter lifted88xj XJ Cherokee Technical Forum 14 05-02-2006 02:19 PM
