99 cherokee trans filter/screen ??? where do buy - JeepForum.com
post #1 of 6 Old 03-11-2011, 01:14 PM Thread Starter
02grandy
02grandy's Avatar
ok i have a 99 cherokee classic 4.0L with the AW4 4 speed auto trans. I been running new fluid through and getting it all bright red again. I will soon be dropping it to replace the filter /screen. people say its a metal screen. the dealer wants $80 other parts stores want $20-40. if its metal can you just clean it with brakeclean or something? are aftermarket ones not as good as the factory one? what aftermarket ones are good ?
02grandy is offline
post #2 of 6 Old 03-11-2011, 01:26 PM Thread Starter
02grandy
02grandy's Avatar
can you had a cork or rubber gasket or have to seal it back up with RTV blue stuff ?
02grandy is offline
post #3 of 6 Old 03-11-2011, 01:57 PM
sjc619
I just changed mine, 98 SE, with the one from napa, it was about $50 but perfect fit and had a rubber gasket. The PO had tried the RTV route and aside from him striping the bolt holes by over tightening, the RTV did a pretty lousy job and it leaked all over. I would spend the money to get a new filter and new gasket.
http://www.napaonline.com/Search/Det...+50038+2038004
sjc619 is offline
post #4 of 6 Old 03-11-2011, 02:27 PM
Dbiked
you dont even really need to change the filter/screan. . . All the contaminants stay in the fluid, the screan just keeps them from leaving the bottom pan. thats why there is a drain plug on the AW-4, unlike most other trannies out there. So just drain and fill.
Utah jeep crew member #32
Dbiked is offline
post #5 of 6 Old 03-11-2011, 05:25 PM Thread Starter
02grandy
02grandy's Avatar
for 138k my fluid looked like it was never changed or changed once. dark dark brown maybe black. since i did my rad job i was filling it up and starting it at idle and letting it pump out lower trans line that goes on lower rad. im 3/4 of the way there get it back to RED RED. its a red brown now . i dont have any problems with the trans dont think its leaking any where and i see orange silicone around the edges. i say to my self drain it again and fill it up but i want to know whats in there lol . clean the magnet and clean the filter. well the most important deal right now is doing the trans service on my grand cherokee 42re . fluid,filter, adjust bands, and add drain plug. i have a reuseable gasket on that one so that will be nice. can't figure out what drain plug to use....
02grandy is offline
post #6 of 6 Old 03-11-2011, 05:47 PM
djb383
About $25 at Advance Auto for new filter and gasket, IIRC.......plus dropping the pan gives u a chance to clean the inside, inspect the magnets, etc. The drain plug is what makes the pan drop so easy (once u get the tube separated). Old filter just unbolts, new one bolts up. If u don't change the filter, u'll always wonder. Very light film of RTV both sides of gasket and just snug (criss/cross pattern) on the pan bolts.
djb383 is offline
Anyone got an LCD screen in their Cherokee? Holder350 XJ/MJ Cherokee Non-Technical Forum 3 11-10-2009 09:27 PM
Trans Filter... FLNICK XJ Cherokee Technical Forum 3 11-29-2008 07:05 AM
'99 Cherokee navigation screen Snottus XJ Cherokee Technical Forum 4 12-04-2007 11:33 AM
Fuel Filter 99 4.0 Cherokee?? 159.98 for the filter alone? Mike94ZLT1 XJ Cherokee Technical Forum 24 05-07-2007 05:04 PM
trans filter djkt XJ Cherokee Technical Forum 2 09-12-2006 06:58 PM
