99 Cherokee Sport 4.0L - All gauges failure - JeepForum.com
post #1 of 7 Old 06-14-2008, 02:30 AM Thread Starter
searcherrr
Coming from my first thread posted here:
http://www.jeepforum.com/forum/showt...45#post5309245
We have purchased our first Jeep and we love it. I found a WONDERFUL deal for $4k at 90k miles and its in great internal/external shape aside from 1 lil problem. It is a beautiful Amethyst blue/purple color and was a 1 owner vehicle. It is almost in too good a shape to use for what we bought it for (muddin), but thats what its for.... to go walk the dog somewhere he can run. The dog should be feeling very special right about now cause that was the sole reason behind getting it, not to mention not wanting to have to clean the other car all the time.
Now for the problem:
From time to time all the gauges on the instrument panel cease to function. This usually seems to happen at idle/park or traveling at low speeds in a neighborhood. I've read up a lil bit and some people think this could be related to humidity/rain too.
In any case the intermittent gauges failing is always accompanied by:
Check Engine light comes on
Air Bag light comes on
"No Bus" or "No bu5" shows on the odometer
Vehicle mechanical functions do not seem affected. IE: The engine still runs and so does everything else. A restart of the Jeep usually gets rid of it, but it does pop up again from time to time.
searcherrr is offline
post #2 of 7 Old 06-14-2008, 05:39 AM
Crystalship1
Crystalship1's Avatar
Read This: http://www.jeepforum.com/forum/showp...64&postcount=3
And I'll add to check (clean & tighten) the grounding strap located on the firewall (under the hood) directly below the driver's side wiper arm.
Good luck!!!
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline
post #3 of 7 Old 06-14-2008, 01:25 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Check this link for some No Bus repair info. The Cherokee is very similar. -http://www.jeepforum.com/forum/showthread.php?p=1339049 -
CJ7-Tim is offline
post #4 of 7 Old 06-18-2008, 10:09 PM Thread Starter
searcherrr
Thanks for the great information.
Where is the procedure for removing the dash etc...? Is it that easy? Where are the screws/bolts etc...?
post #5 of 7 Old 09-13-2008, 06:06 PM
Xjcrusader
Xjcrusader's Avatar
99 XJ with nobus here. its intermittent so I am not taking that thing apart but if somebody could link us to the dash procedure it would be good to bookmark it!
Xjcrusader is offline
post #6 of 7 Old 06-24-2013, 11:39 PM
mrgodlike
A friend of mine told me about the ground wires under the center console, I removed and cleaned them today. No problems yet, everything else I tried failed within minutes, except this. Give it a try. Update: still having the gauge issue after sitting overnight.
mrgodlike is offline
post #7 of 7 Old 07-02-2013, 06:02 PM
mrgodlike
So I got a used pcm from the boneyard, had a dealer program it ($65.00) and so far no problems, I'll update in a few days.
Cherokee clutch slave failure gregpalin XJ Cherokee Technical Forum 1 10-02-2009 09:19 PM
Grand Cherokee Speedometer Failure goehm XJ Cherokee Technical Forum 3 05-12-2009 04:11 PM
94-cherokee limited 4.0 poss hg failure! buddy-mugger XJ Cherokee Technical Forum 0 12-10-2008 01:51 PM
95 cherokee sport gas and spedometer gauges not working skierdude52689 XJ Cherokee Technical Forum 6 10-28-2008 01:59 PM
2000 Cherokee 4WD Failure 2000JEEPDW XJ Cherokee Technical Forum 29 11-29-2007 04:09 AM
