99 cherokee head? - JeepForum.com
post #1 of 10 Old 06-29-2009, 08:58 AM Thread Starter
1 ton yj
1 ton yj's Avatar
99 cherokee head?
I just picked up a clean 99 cherokee for cheep because it needs a head gasket. It's got a cylinder missfire code for cylinders 2 and 3 so I'm thinking that's where the leak is if that matters and it has 130k miles. The guy I bought it from said his wife was driving it and all of the sudden it got hot and the radiator blew so she pulled over and shut it off.
How do I tell if I have the imfamous 0331 head? Changing the head gasket is no big deal but I'd rather not have to buy another head. Is there a way to check for cracks in the head myself without having to pay a machine shop to magnaflux it?
1 ton yj is offline
post #2 of 10 Old 06-29-2009, 09:03 AM
MJR
MJR's Avatar
1988
I think the head with problems started in 99 on the WJ and 00 in the XJ/TJ. You can pull the valve cover and see if the oil is washed away (indicating coolant leakage) right in the middle of the head pretty much under the filler cap.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #3 of 10 Old 06-29-2009, 09:48 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you have a distributor, you don't have a 0331 head.
Install a new head gasket and drive around until you ruin the motor. Why would you not have the head tested ?
CJ7-Tim is offline
post #4 of 10 Old 06-29-2009, 09:57 AM Thread Starter
1 ton yj
1 ton yj's Avatar
I have distributorless ignition. Guess I have the 0331. I wasn't saying I didn't want to check the head just that I didn't want to pay somebody else to if there's a way to do it myself.
1 ton yj is offline
post #5 of 10 Old 06-29-2009, 10:07 AM
CJ7-Tim
CJ7-Tim's Avatar
Since you have the 0331, you want to be absolutely sure it is still good. If I take the time and effort to remove the head to install a head gasket, I want to be sure I don't have to repeat myself in a few weeks or months if the head turns out to be cracked. My time is worth money, and I would rather be on the trails than in the garage, so spending a few dollars on a test is worth it to me.
I have an 0331 head on my 2000 and a spare 1999 head in the garage. If I have any head or gasket issues I am going to do the head and exhaust manifold swap and be done with the potential 0331 problems.
CJ7-Tim is offline
post #6 of 10 Old 06-29-2009, 10:14 AM
mgramann
mgramann is offline
post #7 of 10 Old 06-29-2009, 10:18 AM Thread Starter
1 ton yj
1 ton yj's Avatar
Originally Posted by mgramann View Post
Perfect. Where do I get it?
1 ton yj is offline
post #8 of 10 Old 06-29-2009, 10:21 AM
mgramann
http://www.ndtsupplies.com/spma.html
This is the first website I found on google. It may be cheaper elsewhere. There are other brands of this product too.
mgramann is offline
post #9 of 10 Old 06-29-2009, 01:05 PM Thread Starter
1 ton yj
1 ton yj's Avatar
Thanks for the help. Been doing some reading on this and am going to pull the valve cover tonight or tomorrow night and check for the crack between 3 & 4. Like I said I'd rather not have to buy a head but even if I do I'll still be into this thing for less than $1400 so I guess I can deal with it.
1 ton yj is offline
post #10 of 10 Old 06-29-2009, 04:37 PM
AZ Jeff
2014 JK Wrangler
Given that the cost of magnafluxing a cast iron head is going to be in the range of well under $50, I see no reason to use this less reliable method (intended primarily for non-ferrous metals).
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
89 cherokee 4.0 I6 - Cracked Head??? tuggey XJ Cherokee Technical Forum 7 01-05-2010 07:47 PM
93 cherokee head-gasket rebuild. G_baller XJ Cherokee Technical Forum 1 09-29-2009 06:36 AM
1994 cherokee head gasket blowncoupe89 XJ Cherokee Technical Forum 18 09-27-2009 10:30 PM
Milling a cherokee head...few questions.. NitroGoat XJ Cherokee Technical Forum 5 01-14-2009 04:47 AM
Cherokee Head lights stay on cherokeetom XJ Cherokee Technical Forum 29 01-03-2007 02:46 PM
