99 Cherokee Electrical Issue - Started with Windows - JeepForum.com
post #1 of 3 Old 07-03-2012, 11:36 AM Thread Starter
bokey
Hey all - so I'm fixing up my 99 Cherokee (replaced by a 99 Wrangler ), and ran into an unexpected issue. The other day, a storm (of course, wasn't forecasted) hit our area pretty hard and all four windows were down a little less then three inches.
I waited a while, before I tried rolling up the windows, but up nor down will work! I let it set a few more days in the heat, but the issue persisted and seemed to expand. I've noticed that my dome light, windows AND LCD illumination for the odometer does not work.
I'm presuming there is a short somewhere, but I'm not sure where to start. Thanks in advance!
'94 Wrangler - Traded
'87 Trans Am - SOLD
'99 Cherokee Classic
bokey is offline
post #2 of 3 Old 07-05-2012, 11:56 AM Thread Starter
bokey
Bump - I really need a hand here. Thanks!
'87 Trans Am - SOLD
bokey is offline
post #3 of 3 Old 07-05-2012, 08:31 PM
JWELK
First check fuses on passenger side panel, using a voltmeter. Just measure the tabs on each fuse, with the key on they should all have power. From there. remove the drivers side door panel and clean the combination switch.
JWELK is offline
cherokee , electrical , short , water , wiring
89 Cherokee Electrical Issue tball32 XJ Cherokee Technical Forum 5 10-14-2012 07:35 PM
'01 Cherokee electrical issue gepetto5 XJ Cherokee Technical Forum 1 07-31-2009 01:57 PM
Possible Electrical System Issue? (Dash lights, p/locks, windows) bgreman XJ Cherokee Technical Forum 2 11-12-2008 10:05 PM
98 Cherokee Electrical Issue Jeff19 XJ Cherokee Technical Forum 3 01-15-2007 10:57 AM
'99 Cherokee Electrical Issue bonji XJ Cherokee Technical Forum 2 10-31-2005 11:23 AM
