99 cherokee 2.5 lift install questions - JeepForum.com
post #1 of 8 Old 07-10-2013, 02:48 PM Thread Starter
agear
Is installing a lift on a 99 cherokee the same as many other year xjs , and if so what years are the same ? Because I'm trying to read up on how to install a 2.5 rancho suspension lift on my friends xj and I want to be prepared for problems that have come up for people in the process of doing theirs. And problems that pop up after the installation of the lift. Anybody who is willing to give me their experiences doing this would be great. Thanks
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 8 Old 07-10-2013, 03:05 PM
clab0603
Hi I'm currently putting a lift on as well! I also had a 3" on my XJ before new one. My main suggestion to you is load up the bolts to remove with PB blaster. Most will be a bit fussy to come out but if you are careful then everything will go on smoothly! Also what does kit contain?
clab0603 is offline
post #3 of 8 Old 07-10-2013, 04:21 PM Thread Starter
agear
Hi.Okay will do.
Don't know what s in the kit yet. But when I find out I'll post it.
Keep the information coming.
thanx
agear is offline
post #4 of 8 Old 07-11-2013, 01:32 AM
the_weirdo
the_weirdo's Avatar
It's basically all the same regardless of year. Its either stiffer/longer coil springs or spacers for the front and bigger curved springs/more springs/longer shackle/block in the back.
the_weirdo is offline
post #5 of 8 Old 07-11-2013, 03:32 AM Thread Starter
agear
Okay. What are the difficulties one runs into during installation on these xjs ?
agear is offline
post #6 of 8 Old 07-12-2013, 03:44 AM Thread Starter
agear
Bump
agear is offline
post #7 of 8 Old 07-12-2013, 05:45 AM
TheRealKTrain
JK Wrangler
You got an answer. Its identical equipment to what is already installed, just bigger, stiffer, stronger, etc.
You have a lifted CJ... you should know what to expect. Rust, seized bolts, stubborn leafs.
Bring beer.
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #8 of 8 Old 07-12-2013, 06:16 AM
Timo_90xj
Timo_90xj's Avatar
Leaf pack front bolts are stubborn (seize to the bushings; weldnut inside the frame may break loose), same goes for shackle upper bolt. If it's a vehicle from the south I wouldn't much worry.
If it's from the salt belt, bring a case of beer, have an angle grinder with cut-off wheels, and new mounting bolts for the leaf packs/ shackle and LCAs (if going to install aftermarket arms). Bolt size is ~110mm long, 14mm x 2.0 thread pitch; class 10.9 (do NOT get class 8.8!!!), or Grade 8. New U-bolts aren't a bad idea either if the lift kit doesn't have 'em. LCA and UCA bolts can be cut fairly easily, they tend to get stuck inside the bushings and I really see no reasons why anyone would like to use the 12+ years old hardware again..
All LCA and UCA bolts and shackle lower bolts can be replaced with SAE hardware (9/16" grade 8 for the LCAs/ shackle lower, 3/8" Grade 8 for the UCAs), but leaf front bolt and shackle upper bolt needs to be metric.
***Under construction***
Timo_90xj is offline
