99 4.0 not staying on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 99 4.0 not staying on
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
Unread 07-02-2015, 04:51 PM   #1
baronvonbadass
my 99 xj L6 4.0 wont stay on, i can start it like normal and apply gas to keep it on but as soon as i let off it dies, theres a check engine light on but no way to check it since i cant keep it on long enough to take it up the road to get it coded. ive cleaned the IAC to see if that would help but it didnt help at all, ive been told it could be my fuel filter, my fuel pump, my fuel pump relay, or my vacuum hoses, where do you guys think i should do next?
baronvonbadass is offline   Reply With Quote Quick reply to this message
Unread 07-02-2015, 06:02 PM   #2
tjwalker
It's the crank sensor!
tjwalker's Avatar
I'd suggest that you beg, borrow or rent a code reader. Your local parts store may be able to help you with this.
There are WAY too many possibilities for us to make any reasonable guesses as to what you should do. You MUST have this code.
When you get the code(s), post the EXACT codes here for comment; not just a description. With OBD, the devil is definitely in the details.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote Quick reply to this message
Unread 07-03-2015, 01:34 PM   #3
baronvonbadass
ok so i borrowed the coder from advanced auto parts and no codes were coming up, the guy said its probably the camshaft position sensor so its on order for me to pick up today, il let you know if its working after that
Unread 07-03-2015, 01:58 PM   #4
billwoot
Only buy mopar sensors. This one from advanced will probably be junk too. And get the code throwing parts won't fix things unless you get lucky..
99xj sport. 4.0 d30/c8.25. Aw4 np-231
billwoot is offline   Reply With Quote Quick reply to this message
Unread 07-03-2015, 05:15 PM   #5
baronvonbadass
its running now
