98 xj no gauges - JeepForum.com
post #1 of 7 Old 07-09-2013, 10:12 AM Thread Starter
rubicon17
98 xj no gauges
the other day the gauges all dropped out, they would randomly comes back on while driving and quickly go out again, next day i had no problems? read about the connections to the cluster so i pulled it all apart and looks good so plugged it back in. if it continues to do it what else can i look out for?
HAWAIIAN KONA COFFEE FORSALE PM ME FOR INFO
rubicon17 is offline
post #2 of 7 Old 07-09-2013, 10:19 AM
CCKen
CCKen's Avatar
The instrument cluster connectors pins and pin cavities may look good but you may need a replacement connector - that was covered by a Chrysler TSB. The connector kit is available from your Chrysler dealer.
CCKen is offline
post #3 of 7 Old 07-09-2013, 10:50 AM Thread Starter
rubicon17
anyway to tell if it already has it? i just remember the plugs being green and clean. whats different about the upgraded part.
post #4 of 7 Old 07-09-2013, 12:58 PM
CCKen
CCKen's Avatar
The upgraded connector has improved pin cavities that grip the cluster connector pins better.
Refer to this thread:
http://www.cherokeeforum.com/f51/fix...cluster-88247/
CCKen is offline
post #5 of 7 Old 07-09-2013, 03:02 PM Thread Starter
rubicon17
hmm i didnt have a no bus displayed but the airbag light was on. hopefully unplugging it re connecting it does the job dont really want a hack job wiring some other plugs in.
post #6 of 7 Old 07-10-2013, 02:58 PM
johnboysxj
Probably a short. Are you blowing a 15 amp fuse under the hood?
johnboysxj is offline
post #7 of 7 Old 07-10-2013, 09:55 PM Thread Starter
rubicon17
nope, no fuses blown, it has only done it once and the gauges dropped in and out a few times
