im looking at an XJ this sunday, and the seller says the jeep needs an oil pressure sensor, and that there is a CEL for a Generic trans code.
seller states "mechanic said that the oil pressure sensors are commonly failing on these vehicles, and are easy to replace, its a $25 part"
oil pressure sensor:
1. does anyone have any idea how much the oil pressure sensor will cost?
2. is it common for them to go bad?
3. should i be worried about anything else if this oil psi sensor is broken?
the seller says the trans code is being thrown because the back light for the gear selector is out, he is going to text me the codes tomorrow.
trans code:
1. is this a common thing?
2. is there a list of XJ trans codes somewhere?
