98 XJ, "needs oil pressure sensor", and "CEL is on for generic trans code's" - JeepForum.com
post #1 of 10 Old 12-10-2009, 09:43 PM Thread Starter
Grip
im looking at an XJ this sunday, and the seller says the jeep needs an oil pressure sensor, and that there is a CEL for a Generic trans code.
seller states "mechanic said that the oil pressure sensors are commonly failing on these vehicles, and are easy to replace, its a $25 part"
oil pressure sensor:
1. does anyone have any idea how much the oil pressure sensor will cost?
2. is it common for them to go bad?
3. should i be worried about anything else if this oil psi sensor is broken?
the seller says the trans code is being thrown because the back light for the gear selector is out, he is going to text me the codes tomorrow.
trans code:
1. is this a common thing?
2. is there a list of XJ trans codes somewhere?
Grip is offline
post #2 of 10 Old 12-10-2009, 09:48 PM
medicmandan
medicmandan's Avatar
I drove 8 XJ's while I was shopping around. Two showed no oil pressure reading. I bought one of them. Picked up a sending unit from Autozone ($25). Still doesn't work. Was easy to replace but it didn't solve the problem so I'm off to do some more trouble shooting. I've read in several posts that it's advisable to pick on up from the dealer.
medicmandan is offline
post #3 of 10 Old 12-10-2009, 09:55 PM Thread Starter
Grip
interesting.
how much are they at a dealer?
Grip is offline
post #4 of 10 Old 12-11-2009, 05:13 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
An oil pressure sending unit will cost a bit more from the dealer but worth every penny in reliability and accuracy with your factory gauge.
Before I would buy an XJ that showed no oil pressure on the gauge, I'd bring along a mechanical oil pressure gauge (they can be rented), screw it in where the sending unit currently resides and verify oil pressure. Then you'll know exactly what the oil pressure is. Don't you really want to know? It very well may be that unit but with being such an easy fix, most of the time the SELLER would replace it themselves. SO verification of the problem seems like a reasonable thing to do and certainly any seller that isn't hiding anything would allow this to be done.
Common codes for a faulty neutral safety switch include both P0700 P0705. And yes, the backup lights are involved in the NSS circuit so not having reverse lights oftentimes coincides with a faulty switch. This switch can oftentimes be disassembled, cleaned, regreased and reinstalled to restore function.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 10 Old 12-11-2009, 09:52 AM
JrTjK
1978 FSJ Wagoneer
definitely what he said ^ about checking with mechanical gauge
Oil Pressure Sender*56031005 by the Jeep Specialists | Morris 4x4 Center
here is the other one he's talking about Neutral & Backup Lamp Switch*4882173 by the Jeep Specialists | Morris 4x4 Center many people attempt to clean them first before buying new, some still like to just replace...that's up to you, if that's even the issue.
best of luck with the new jeep!
JrTjK is offline
post #6 of 10 Old 12-11-2009, 08:02 PM Thread Starter
Grip
this thread answered both of my questions pretty quickly.
thanks everyone.
Grip is offline
post #7 of 10 Old 12-12-2009, 09:36 PM Thread Starter
Grip
ok, so im going to check out this jeep tomorrow, the seller has been really honest, and really helpfull. seems like it could be "the one", just have to check it out visually.
is it bad for the vehicle to drive around with a bad, or dirty NSS?
Grip is offline
post #8 of 10 Old 12-13-2009, 04:28 AM
tjwalker
tjwalker's Avatar
I'd still check oil pressure if I were considering buying it. Or just swap in a new sending unit; takes all of 10 minutes. Low oil pressure would have a direct affect on the amount I would offer for it. You don't want to have hindsight on this and the seller should not be insulted by your desire to know what the oil pressure is.
It is probably okay to drive around with a faulty NSS, except for you might not have reverse lights and you could have trouble starting it.
tjwalker is offline
post #9 of 10 Old 12-13-2009, 08:37 AM Thread Starter
Grip
I checked it out 20 minutes ago. Everything looks good on it. Fog lights don't work(probably the switch), and the reverse lights don't work(nss).
I noticed that the turn signals blink fast, none of the bulbs are burned out. Is that because of the NSS too?
Grip is offline
post #10 of 10 Old 12-13-2009, 07:51 PM Thread Starter
Grip
ended up buying the XJ.
put 180 miles on it today, did a little 4hi action, truck is solid, im happy.
Grip is offline
Local JY question... "A Deal" or "A Hole" Fletch8672 XJ/MJ Cherokee Non-Technical Forum 6 12-10-2009 06:10 PM
Turn signals "on", when drive lights "on" R5ROD XJ Cherokee Technical Forum 3 07-07-2008 03:22 PM
Driver side door "popping", need new restraining "bracket"? 19OlllllllO41 XJ Cherokee Technical Forum 16 10-02-2007 11:08 AM
Will Hayden adapter kit "391" work with a B&M stacked plate trans cooler? husker25 XJ Cherokee Technical Forum 1 12-04-2004 10:32 PM
oil pressure "switch" or "sensor"? mans XJ Cherokee Technical Forum 2 07-20-2004 09:43 AM
