98 XJ Clunking problems when turning - JeepForum.com
post #1 of 5 Old 04-24-2010, 06:32 PM Thread Starter
98ia-xj
2005 KJ Liberty
Hey guys I am not at all mechanically inclined here, but I am trying to become...I have a question and would love to hear some ideas before i take it to a shop.
I have a 98 XJ, with what I was told was a HP D30 in the front, SYE, and Chrysler 8.25 in the rear. The rear i know is the 8.25, the SYE, dont know how to tell, and the other, of course not totally sure.....anyways, I was told awhile back that I a front Driverside Ujoint going out cause of a popping noise when on a trail one day. Multiple ppl agreed it was bad. Well I took it too a shop and they replaced, it was bad. However, I am still getting a clunking noise almost anytime i turn left. If I turn really fast and hard, i hear it. If i turn slow, i hear it. Sometimes when I go over bumps in the road I hear it. Most of the time its turning I hear it. After the Ujoint being swapped out, it almost sounds and FEELS, yes I can feel something in the steering wheel now, its coming from the center front of the Jeep.
Also, on a new area I have problems with. When I come to a complete spot if I dont slow down really slow, there is a clunk and a "nudge" feeling coming from the rear. I was told rear driveshaft Ujoint. The shop it was at yesterday told me it was solid as can be, but there was a noise coming from the T-case.......any ideas on that one?
Thanks for any advice guys...
1998 Cherokee Limited XJ-Stock :-( Except for a K&N Air Filter.......
98ia-xj is offline
post #2 of 5 Old 04-24-2010, 07:24 PM
Spencer43783
If the driver side u-joint was bad don't you think the passenger side is probably bad too? Lol
What I mean is, are you sure it's coming from the driver side? If it is then I would say it's prolly sway bar bushings. While you're under there take a look at everything and make sure all the nuts are tight. And look at the ball joints and tie rod ends and make sure they're good. I don't think those will cause your clunking but it doesn't hurt to look!
Let us know what you find :-)
1998 Cherokee Sport 4.0L-AW4-NP231-C8.25--Black, trim removed and chopped. 31" Goodyear Wrangler Duratracs. 3" lift coming soon.
1984 Grand Wagoneer--Sold. I'll miss the old girl.
Spencer43783 is offline
post #3 of 5 Old 04-24-2010, 07:30 PM Thread Starter
98ia-xj
2005 KJ Liberty
The shop it was at only said the one was bad....i will have to check the other things.....reading some other post i was thinking maybe--steering box, tierod, or ball joint?
98ia-xj is offline
post #4 of 5 Old 04-24-2010, 07:56 PM
COLOUXJ
2010 JK Wrangler
i would check your tie rod ends, mine were bad and caused a clunk/popping when turning. if the bushings look split that is what was causing my issues
COLOUXJ is offline
post #5 of 5 Old 04-25-2010, 09:14 AM
portcityXJ
1995 XJ Cherokee
how much of a job is it to replace the TREs? i have the same popping in my 95. TREs seem like a good (and cheap) place to start.
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline
Clunking and grabbing while turning right ArmySgt97 XJ Cherokee Technical Forum 2 03-01-2009 06:11 PM
Clunking while turning OffSgt XJ Cherokee Technical Forum 3 02-18-2008 05:54 PM
clunking when turning? powerman556 XJ Cherokee Technical Forum 3 09-25-2007 09:53 AM
Clunking under front end when turning?? skyjacked94xj XJ Cherokee Technical Forum 2 04-11-2005 07:26 PM
Clunking when turning Blue XJ XJ Cherokee Technical Forum 6 11-28-2004 11:20 AM
