98 xj blowing hot air when a/c is on - JeepForum.com
post #1 of 5 Old 02-10-2011, 02:25 AM Thread Starter
matt62485
I'm fairly mechanical savvy, but hvac units are not my cup of tea. My XJ's heat isn't the best in the world, but it will keep you warm... however, so will the A/C. I put one of them DIY freon cans on it and it says it's full, however my belt will start squeaking as when the compressor kicks on and the pressure drops. I'm scared to add anymore b/c it'll carry it into the red on the pressure gauge on the filler bottle. Even when its 35 degrees out the A/C blows hot air, not even the fan or anything will blow remotely cool air. spring is coming up, and i need some a/c .
my only guesses are it's actually low on refridgerant, evaporator is shot, the compressor is toast, or the duct isn't opening/closing from the heat position, im not sure if its like my caliber srt-4, but it runs off a throttle cable type knob for the damper adjustment. seems these are vacuum oriented or something on the xj?
Any ideas?
[]IIIIII[]
matt62485 is offline
post #2 of 5 Old 02-10-2011, 01:39 PM Thread Starter
matt62485
bump for some daytime exposure
[]IIIIII[]
post #3 of 5 Old 02-10-2011, 04:57 PM
djb383
Do u have the temp selector (knob on the right) turned to cold? The heated air is way stronger than the cooled air.
djb383 is offline
post #4 of 5 Old 02-10-2011, 05:28 PM
AZ Jeff
2014 JK Wrangler
First off, just adding a can of refrigerant on "general priniciples" is NOT a good idea on an R134a system. It was not a bad plan in the old R12 systems, but the R134a systems have a VERY fine line between the right amount of refrigerant, and too MUCH refrigerant.
Owing to this, it's is always best to start with an EMPTY system (evacuated, of course), and refill BY WEIGHT the specified amount.
Next thing is you need to use a REAL refrigerant charging manifold that measures both low and high side pressures. Then you also need a temperature/pressure chart to know what the correct values are once the system is filled and you have measured the ambient air.
Come back with that data, and we can help you figure out what is REALLY wrong with your AC.
BTW, the suggestion from "djb383" is not a bad start.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 5 Old 02-14-2011, 12:37 PM Thread Starter
matt62485
lol. i dont typically run the a/c with the temp knob on hot? yes, it was turned on cool, still blowing out hot air just like the heat was on. theres no difference where the temp (cold-hot) was located or where the feet/head/defrost was selected even on a/c. the temp is just hot.
ill carry it somewhere so they can vac it and recharge it
[]IIIIII[]
what's with all the XJs blowing up? FairlanePhil XJ/MJ Cherokee Non-Technical Forum 14 09-07-2010 11:14 AM
ac keeps blowing off jeepsteads XJ Cherokee Technical Forum 5 04-11-2010 06:19 PM
XJ 4.0 Blowing Oil F1504x2 XJ Cherokee Technical Forum 10 06-23-2009 03:52 AM
Blowing hot air with A/C on Tonto XJ Cherokee Technical Forum 1 05-20-2004 06:45 PM
