Quantcast 98 XJ 4.0 Starting Issue... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 98 XJ 4.0 Starting Issue...
Old 09-21-2009, 06:36 PM   #1
rustedxj
Ive got a 98 XJ 4.0 Auto. When I go to start it it cranks and cranks and cranks and will either stumble and not start or fire up. If it stumbles I can turn the key off and try again and she usually fires up. I just replaced the CPS and that did nothing for me. When I turn the ignition on I can hear a faint noise from the fuel pump. Other than this issue I have no other issues when its running.
The battery is good and the cps is brand new so Im eliminating those from the problem. I was either thinking a starter issue or fuel pump?
Also the cap rotor wires and plugs are probably about 4 months old now.
Thanks In Advance
Chris
1998 XJ: Rusty's 4.5" AAL, 32x11.5 dunlop mud rovers on 15x8 crager steelies
Firefighters Jeep Club
http://groups.jeepforum.com/Firefighters_Jeep_Club
rustedxj is offline   Reply With Quote
Old 09-21-2009, 06:46 PM   #2
MrJCRod
I came across a few threads on this. It's most likely a fuel delivery issue. Other members have said that it is either the check valve in the pump or the fuel pressure regulator. Either one will let the fuel drain back to the tank and not keep prime so cycling the key without trying to start it once or twice will usually get it to fire up quicker... I was going to replace my regulator but now the problem went away on it's own. It started to happen to me a day after wheelin' and getting stuck in water for a couple of hours but now it fires right up...
MrJCRod is offline   Reply With Quote
Old 09-21-2009, 07:44 PM   #3
yingpin
Happens to my 98XJ too, sometimes I will turn the key in the on position and let the fuel pump run for a few seconds and that works.
I too feel that it is easier to turn the key twice than it is to actually replace the issue.
I know this is not the best solution, but it works currently for me.
[]IIIIIII[]
1995 YJ 2.5 RE SD, 2'BL 33x12.5 Dunlop Mud Rovers
1998 XJ Sport - RC 3" Full Pack, JKS Discos
http://www.jeepforum.com/forum/f22/98-xj-mild-build-documentation-971709/
yingpin is offline   Reply With Quote
Old 09-21-2009, 07:55 PM   #4
mortalenema
Drivin' me nuts...
mortalenema's Avatar
Yeah, it's most likely a bad pressure regulator or leaky injectors. I'd bet it's the regulator. Time to drop the tank and install a new assembly. (It's not that hard.)
Don't waste your time on a check valve. That's what I did. I started with a bad regulator, installed a check valve, and ended up with bad injectors. Maybe they weren't related, but something tells me that doing it right the first time would have saved me a lot of time and money.
'99 Classic: "Emma"
8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite
JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s
Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents
Jeeps with Teeth #1
MN Jeeper #14
_____________________________________________
"When is the best time to do things? Who is the most important one? What is the right thing to do?"
"BORN TO WHEEL" PRODUCTS FOR SALE
**********More designs here**********
mortalenema is offline   Reply With Quote
Glock Forum
