98 sport 4.0 Bad engine - Page 3 - JeepForum.com
 7Likes
post #31 of 35 Old 02-06-2017, 11:16 PM
bluejunior
bluejunior's Avatar
Originally Posted by kengoff View Post
Get yourself a Haynes repair manual, you will need it for all kinds of things on these Cherokee's.
By the way I am also in Evans,wv.
Screw Haynes, get a factory service manual. Infinitely more helpful.
Lifted, Locked, Stiffened
bluejunior is offline
post #32 of 35 Old 02-07-2017, 05:06 AM
75SV1
I have both manuals. Or the Chilton instead of the Hayes. There are somethings I like the instructions in the Chilton or Hayes. For the engine, I'd go with the factory. Also, there is one of the head bolts that gets sealant on the threads. I'd probably get a new set of head bolts. You can reuse them once. If they were reused, it is common practice to put a splotch of yellow paint on them. Not knowing the history of the engine, I'd spend the money on new ones. Also, as suggested, puling the motor might make things a lot easier.
As to the bearings, you would have to measure the journal bores and the OD of the crank. Also, check with plasticgate (??sp). It is was strands that flatten when in an assembly. To check your actual clearances.
75SV1 is offline
post #33 of 35 Old 02-07-2017, 07:35 PM
ECL
To the OP - are you sure you don't want to put in a used motor? The price of the new parts will start to add up.
wvabeer likes this.
ECL is offline
post #34 of 35 Old 03-19-2017, 05:52 AM Thread Starter
wvabeer
Follow up, I used the Morris 4x4 web site for my online engine specs, replaced busted piston with a used one, light hone, new oil pump (old one cracked),new rings, rods and mains, gasket set and local shop redone the head. total $396. It runs great.
tjwalker likes this.
wvabeer is offline
post #35 of 35 Old 03-19-2017, 09:10 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Way to get under it quickly and inexpensively man! I'd say that is possibly the best $396 you have ever spent.
Thanks for the update.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
