98 Green XJ - Daily Driver Build - Page 33 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 98 Green XJ - Daily Driver Build
Poison Spyder DeFender Inner Fender KitsCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WDJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 05-21-2013, 08:47 AM   #481
DNFJ
DNFJ's Avatar
Did you just unbolt the clutch fan?
needs pics and basic hand holding.
Wannabe Desert Rat
'00 XJ 6.5" w/ 33s
Built Not Bought #704
DNFJ is offline   Reply With Quote
Unread 05-21-2013, 09:06 AM   #482
Project1
I uses a sawzall and cut that thing right off. I also changed my serpentine belt configuration so you have to cut it in enough so the belt does not hit. there are pics on my thread about it.
Project1 is offline   Reply With Quote
Unread 05-21-2013, 09:15 AM   #483
Project1
Unread 05-21-2013, 09:28 AM   #484
DNFJ
DNFJ's Avatar
Why wouldn't you just unbolt the fan?
Wannabe Desert Rat
'00 XJ 6.5" w/ 33s
Unread 05-21-2013, 09:42 AM   #485
Weeder1
June 1st!!
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote
Unread 05-21-2013, 10:14 AM   #486
Project1
if you look in the pic where I showed how I cut it .. you can see that when you change the serpentine belt configuration, you have to cut it in enough so the belt does not hit where the old fan use to be. Also gives you a little more HP
Unread 05-21-2013, 10:15 AM   #487
Project1
Originally Posted by Weeder1 View Post
June 1st!!
man my schedule has gone bad to worse.
Unread 05-21-2013, 11:05 AM   #488
DNFJ
DNFJ's Avatar
Why did you even need to change the belt config is what I don't get
Wannabe Desert Rat
'00 XJ 6.5" w/ 33s
Unread 05-21-2013, 11:26 AM   #489
Project1
when I guess you could leave the pulley if you wanted to ... but you can use a shorter belt which is nice because the length of the belt affects the revolutions per min... which effect the charging power of your alt and power steering. Just like using an over drive pulley (like the genright one I have) lets you get more out of your power steering at idle ... you get the same results by using a smaller pulley too. Also less resistance gives you a few HP. I'm about to drop my AC and relocate my ALT and run a super short belt .. which makes a nice difference in steering at low speeds and gives you more of a charge from your alt at idle. I think its worth it ... but that's just me.
Unread 06-05-2013, 12:00 PM   #490
MOBBiN
MOBBiN's Avatar
Updates? It's been a while
2001 Silverstone Metallic Classic/Limited XJ
April 2014 COTM
MOBBiN is offline   Reply With Quote
Unread 06-06-2013, 05:18 AM   #491
Project1
I know man I'm slacking .. School is just hitting hard and with work ... sleep .. whats that ... but its all good its not forever.
I really want to do a cage next but SFR (nick) is going to build it for me .. but my roommate beat me to the punch. But with all fairness he busts his as to pay for his jeep and its SUPER sick ..
But i need to replace my brakes and maybe will do the derango brake conversion with the xj master cylinder. and might just get some fog lights ...
I have been slow but the XJ is not close to forgotten ...
Unread 06-06-2013, 07:29 AM   #492
NW99XJ
NW99XJ's Avatar
so how bout a teaser shot of your roommates Jeep?
5" of lift, 33's. Armored, Lighted, Chipped, & Locked up Front. Soon to come: winch, gears, axle shafts, and more...
My Build Thread: http://www.jeepforum.com/forum/f22/f...-build-970888/
Built Not Bought - Senior Member
NW99XJ is offline   Reply With Quote
Unread 06-06-2013, 11:02 AM   #493
Project1
Now that I can do .. HOLY Bad *** jeep ... Ill post up some pics soon, hes got a sweet rig. SFR has done a lot of work on it .. he has stretched, long armed, axle swap, and some other stuff... now they are doing the cage, its going to be awesome too
Unread 06-06-2013, 04:33 PM   #494
mild96xj
you gotta come out to hecksure next time we go
mild96xj is offline   Reply With Quote
Unread 06-06-2013, 04:33 PM   #495
DNFJ
DNFJ's Avatar
I just ordered the same rear quarter panel armor as yours.
Wannabe Desert Rat
'00 XJ 6.5" w/ 33s
