98 Green XJ - Daily Driver Build - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 98 Green XJ - Daily Driver Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBill Baird Motorsports DIY parts - NalinMFG.comComponent speaker deal for your dash - NalinMFG
Unread 03-28-2010, 01:36 PM   #16
kgthekid03
Hey man jeep looks awesome love it with the jk rims. How much did you get those for? And how much was the adapter
kgthekid03 is offline   Reply With Quote
Unread 03-28-2010, 02:41 PM   #17
Project1
Originally Posted by alexrule123 View Post
*Off topic* Project1 do you happen to live in Jacksonville because I thought I saw your jeep the other day.
I do! Pm me, well have to do some jeepin
Edit: Just looked at your jeep .. I'm pretty sure I saw you at the town center driving twards UNF. I'm always checkin out the XJ's
Thanks man
Three hundo (300) Ebay for 5 rims and tires. Had to drive down south and get them and the adapters are about $140ish.
Project1 is offline   Reply With Quote
Unread 03-28-2010, 04:40 PM   #18
alexrule123
Yeap that was me.
2001 Cherokee Limited: My Build Thread
2005 Pontiac GTO 6.0L (DD)
May 2013 COTM
alexrule123 is offline   Reply With Quote
Unread 03-29-2010, 08:14 AM   #19
BassMasterCHS
1993 XJ Cherokee
Yeah, that looks Ocala-ish... or Richloam-ish.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline   Reply With Quote
Unread 03-29-2010, 09:34 AM   #20
GreenMeanie
Hey I got a nice 04 Lancer, wanna trade?
GreenMeanie is offline   Reply With Quote
Unread 03-29-2010, 06:24 PM   #21
Jeeper1973
"project 1"... i was considering either the TJ Rubicon rims or the JK rims like you have.... do you know the rim specs? 17", how wide, Backspace?
I have pretty much settled on getting the RE 3.5 lift in a few weeks, and would like to figure out a few more things about wheel spacers etc. With those tires, how close are they to rubbing? you're happy with 1.25" adapters? That lift looks like more than 3.5"... did you get an extra inch out of that kit?
Nice XJ...
Jeeper1973 is offline   Reply With Quote
Unread 03-29-2010, 11:58 PM   #22
youngwon22
Since it is your DD and all, I assume you expect highway drives...
What are you planning for steering? Some set-ups aren't so highway friendly...
youngwon22 is offline   Reply With Quote
Unread 03-30-2010, 09:21 AM   #23
Project1
Nice XJ...
Hey man Thanks!
Right now with the 255/75/r17 and the spacer, I have no rub at all with the RE 3.5. When these tires wear out I'm going to go larger tires and more lift. I like them so, good for now. I wanted to go with the 16’s and that really is a great way to go, I just found a perfect deal on these so I went with them. Not sure on the back spacing but I posted a picture, they sit flush with the fender.
Unread 03-30-2010, 09:25 AM   #24
Project1
I have not really had any steering problems yet, and no plans at this time really. I think next is disc brakes and lockers.
Since it has street tires, not mt’s, it rides really awesome on the road but off road is kind of bad.
I don’t dive the jeep too fast either. I usually dive like 65 on the highway.
Unread 03-30-2010, 09:26 AM   #25
Project1
Who would ever do that Larry !!!!!!!
It's good to have freinds brother!
Unread 03-31-2010, 07:07 AM   #26
SolerXJ
1995 XJ Cherokee
[QUOTE=
@#$@#$ those studs …errr
I got one out ok, after a little work. The second one no go.
-Tried the double nut trick w/heat
-Tried flatting the sides with the dermal and backing it out …no go w/heat
- Tried the easy out … that broke …err
- Tried drilling a hole though the stud, parallel and using a small screwdriver to back it out… no go.
[/QUOTE]
sounds like you could use these
SolerXJ is offline   Reply With Quote
Unread 03-31-2010, 08:15 AM   #27
Cherokee513
aa
Nice XJ man!...project1, i did the same paint job on the wheels. i love the look. its sharp
Cherokee513 is offline   Reply With Quote
Unread 03-31-2010, 09:28 AM   #28
nbleak21
Love the jeep, and jk wheels... Plan on doing the RE 3.5 lift down the road, and now will have to look into the JK wheels and tires... Silver on Silver should look pretty good!
2004 Jeep Wrangler X - 2" BB, 15x10" MT CLII's, 32" BFG A/T K/O's
2000 Jeep Cherokee Sport- Bone Stock
nbleak21 is offline   Reply With Quote
Unread 03-31-2010, 09:51 AM   #29
slvmart
Those Sears Bolt Outs are a wonderful thing ! I've had them for about 5 years now and they come saved my butt a few times !
slvmart is offline   Reply With Quote
Unread 04-01-2010, 06:44 PM   #30
Project1
OK Solerxj!! Where were you when I was trying to drill that bolt out for 6 hours!!!!
I’ll be adding those to the collection for sure!!
Well the good news is I did get that demon stud drilled out, and the t-case drop on. I hate having to drop the t-case but for now that’s what I’m going to do.
It did fix my problem though.
