98 Green XJ - Daily Driver Build - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 98 Green XJ - Daily Driver Build
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 04-11-2013, 10:49 PM   #241
Project1
I have also been thinking of how I can change the serpentine belt config ... here's what I'm thinking
Errrr.. ill just put this in separate post because I cant figure out how to separate the type and the pics, and put the right text on top of each pic.. wtf
Project1 is offline   Reply With Quote
Unread 04-11-2013, 10:52 PM   #242
Project1
Stock
Unread 04-11-2013, 10:53 PM   #243
Project1
What I'm running now...
Unread 04-11-2013, 10:54 PM   #244
Project1
What I'm thinking of changing to when I put the pulley on (if it has the clearance) ....
Unread 04-11-2013, 10:55 PM   #245
Project1
Where I would like to end up at some point in time, If I ever get around to getting a HO alt and relocating it to where the AC use to be.
Unread 04-11-2013, 11:49 PM   #246
straightsixjeep
Would you have a grooved idler pulley? Thats the only thing Im not sure about in that last diagram, the grooved side of the belt would run on the idler.
straightsixjeep is offline   Reply With Quote
Unread 04-12-2013, 12:17 AM   #247
Project1
Ahh my friend .. good eye .. I didnt catch that .. damn ..
Ill figure something out .. I really want to relocate my alt ... This would be the perfect time to do it ... but I have been so busy I'm just going to fix the pulley problem I have and work on the doors and tail gate and stuff.
Well damn .. that totally just shot down that plan
I was hoping to isolate the AC so it was not hooked up and still have the jeep running so I could take the AC out in my own time .. fab up a bracket and get a new ALT and install it .. then just run a new belt and take the old alt out after everything seemed to be working well.
I could do this then.
Unread 04-12-2013, 01:10 AM   #248
straightsixjeep
Dont worry man you will get it figured out! So you dont want ac? What if you relocated the alt to the ac spot? Fab up a bracket and then incorporate an idler pulley around that area. Then simply remove the current idler pulley. Il have to take a look under my hood to see if you can simply pull the idler, it should affect the ps pump mount. Either way keep thinking up ideas and get other projects on the jeep done, cant wait to see more progress!
Unread 04-12-2013, 01:22 AM   #249
Project1
Have you seen the jeep tj 4.0 they use an tensioner ... that has a spring that keeps the right pressure on the belt at all times... I wonder if I can use that. I really like the way you think!
Its called an automatic tensioner pulley or something like that.
oh and the ac.. I think my heater core is bad and my ac and heat stopped working.. but I'm doorless all the time and I NEVER use it, and I thought it would be good for the alt to get it up high to keep it out of water and stuff.
Heres a pic of the alt up high and the auto tension pulley
Unread 04-12-2013, 01:27 AM   #250
Project1
score .. Rugged Ridge Tensioner Pulley (05-06 Wrangler TJ w/4.0L Engine) .. 60$
What I need to find is that bracket that bolts to the 4.0 that is for an alt and holds that pulley .. maybe it will bolt right up .... Sounds like its going to be junk yard time
Unread 04-12-2013, 02:14 AM   #251
straightsixjeep
Now your on the right track! I have never peeked into a tj engine bay, I like how high the alt is and that tensioner would work perfect there. It looks like if you find that alternator bracket with the auto tensioner, as long as it bolts right up your in business other than finding the right size belt. Got me interested man
Unread 04-12-2013, 02:55 AM   #252
MrSundays
Seems possible. Do you think it will clear the WP and/or the fan? The tensioner that is. If so, that's a genius mod. That couples with the top alternator, you win sir haha. Let me know how it goes!
Sent from my pocket brick
[URL="http://www.jeepforum.com/forum/f22/syd-tj-slower-than-molasses-2368441/#post22540729"]Syd the Sloth Build[/URL]
[B]F-22 Specialist[/B]
MrSundays is offline   Reply With Quote
Unread 04-12-2013, 04:05 AM   #253
Project1
I dont know ... That would be the reason I hope it works (if it has the clearance) ! ..
but the only way to find out is to try it .. so when I put the pulley on Ill see how it goes.
I really need to find one of those TJ alt brackets
Unread 04-12-2013, 04:19 AM   #254
MrSundays
Better get to the junk yard!
Unread 04-12-2013, 04:27 AM   #255
Project1
Yea.. thats prob the only place im giong to score one of those.. maybe ebay
