98 Green XJ - Daily Driver Build - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 98 Green XJ - Daily Driver Build
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 03-04-2013, 07:53 AM   #151
Project1
Some stuff is starting to roll in .. and JCR shipped today!
JCR
Scheduled Delivery:
Thursday, 03/07/2013, By End of Day
Project1 is offline   Reply With Quote
Unread 03-08-2013, 08:23 AM   #152
Project1
Got the skid but not the bumper ... It was shipped separate, will be here next week, I would put the skid on but the nut strip is with the bumper :/ ... (elevator music )
I did get the skid painted, used dupicolor spray on bedliner, same as the quarter panels. The skid weighs around 40-60 lbs and same with the bumper .. So this will add about 120lb to the rear... which I hate adding weight, however the weight in the rear is nice, It does help the rear end stick better and not get loose in turns, so that will be good, and I'm excited to have a tow hitch ... about time.
After all this is on next will be the MJ tailgate, then redo the roof rack... I use it a lot so I'm going to extend it to the length of the roof. I went from 2 stock bars to 4 stock bars when I added the tires, just got two more, so Ill extend it about 20" longer and go to 6 stock bars, I thought about going gutter mount or doing something different like an ARB rack, but I like my rack and it works well so Ill go with it. Also it leaves the gutter area open for a cage, I do want more of a roll cage vs exo cage... but the top bars of the cage I want to run out side just under the gutter because I'm always door less then make a half door skin .. in the works
then ... back to working on the motor, before the cage, For the motor I still need ...
1) get the neon injectors in
2) msd 6a offroad box and high vib coil
3) HO alt (2002 derango) and relocate it to the ac spot
4) 2nd redtop battery
5) PSC transmission cooler w/ fan, and one of these things http://hesco.us/products/7882/coolin...h#.UT3JIdZwe5I
6) genright overdrive power steering pulley
and I think that's it for now
Unread 03-09-2013, 03:26 PM   #153
Mtb Jak
Definitely cant wait to see the skid/bumper combo!
120 pounds but itll be able to get drug over rocks and backed into trees so the trade off is definitely worth it!
Mtb Jak is offline   Reply With Quote
Unread 03-09-2013, 03:42 PM   #154
Project1
That's what I'm thinking !
And its going to be solid with the quarter panels, bumper and skid .. I can't wait
Unread 03-12-2013, 04:31 PM   #155
Project1
Roll call ..... All parts are in. Jcrs stuff is so solid ...it's beefy and the welds are great ..... Looks perfect a++ for jcr again.
Unread 03-13-2013, 12:09 PM   #156
Project1
Paints drying right now
Unread 03-13-2013, 12:19 PM   #157
Weeder1
Lookin good man.
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote
Unread 03-13-2013, 12:20 PM   #158
Project1
Unread 03-13-2013, 12:24 PM   #159
Project1
Originally Posted by Weeder1 View Post
Lookin good man.
Thanks brother .... That dupicolor bed liner really has a good finish and hold up reallllllly well for some cheap spray can stuff. I have put a little beating on my quarter panels and that stuff holds strong.
Unread 03-13-2013, 12:24 PM   #160
Mtb Jak
Originally Posted by Project1 View Post
Very interested to see how it mounts up with the gas tank skid! Take lots of pictures!
Unread 03-13-2013, 12:33 PM   #161
Project1
Me too, the quarter panels, bumper, & gas skids going to be a sweet combo.
I can't wait to put this on.
Unread 03-13-2013, 01:49 PM   #162
Weeder1
I use that **** on everything, rockers, quarters, bumpers, wheels. Lol i like that if you scratch it, you can spray the scratched area and it blends regardless.
-98 xj sport-
Unread 03-13-2013, 01:54 PM   #163
Project1
Painted ..... Check
I'll let this dry for a day and maybe get this on Friday.
Unread 03-13-2013, 01:55 PM   #164
Project1
For sure .... Ha ... I think this stuff is holding parts on
Unread 03-13-2013, 02:04 PM   #165
Weeder1
Haha true! I want quarter armor so much more now seeing yours close up. I think when u throw that bumper on ill see the pic and have to go buy some. Lol
-98 xj sport-
